**check out what i did**
1.grill = 1hour waiting black+gun metal
2.headlight <--took so long gunmetal housing + black eyes
i had no time to take pictures of everything but i took some. enjoy.
1. took off bumper
2. took off headlight
3. baking broil Hi temp 6 minutes (took out wires and converter)
4.disasambling
5.sanding and primering
6.painting
7. housing (more like metalllic gray)
8. headlight black eye housing + some metallic part of eye
9.grill
10. side
11. front
12. close up
13. front bird view
well im lazy to cover my plate.
1. took off bumper
4.disasambling
6.painting
9.grill
10. side
11. front
12. close up
13. front bird view
Man props to you for manning up and doing the headlights on your own. What sealant did you use to seal it back? And on a scale of 10 (10 being hardest), how hard would you rate the headlight job to be for someone with zero expertise in that field?
re to g37 Sam if you never had that kinda work. it will be hard thing to do
risky thing is u can break it when u open the cover(factory silica is damn tighten, so it dodsne't get fully losen with baking) n u need lil painting skill as well. comparing to other mod i have donee. exhaust and intake. it's 2x maybe lilmore harder.
and i go to home depot and looked for silicon with water proof and heat resistance and clear color
I might go to the junkyard and try it out on a set of used headlights for fun.
any primer for plastic should be fine (has to be water proof and heat resistance) but u get to sand it till the silver (chrome) part is gone. if you dont sand it. paint will get cracked when it's TOO hot
How you put the headlight back together without getting any moisture inside? I was thinking about baking my headlights just to remove the amber marker but I'm afraid of messing up my headlights.
okay heres the top for not getting moisture inside.
go to home depot and get moisture remover solid product. but clear one. grind it and put it inside of headlight. remove all the original silicon as much as you can. then put new water proof silicon. get like 6 wrenches and tight them up for like 1~2 days after that i put crazy glue over it since it's waterish it will get into small vapor spot that is made when silicon is dried. remover solid product will be disappear as time goes by...
i tested it before i did it so should be fine if you do properly.
