My 1st check engine light YAY
Old Jun 12, 2009 | 09:35 AM
XMMAN's Avatar
XMMAN
well last night I was out and got my first check engine light.. miles just crossed 9000 im kind of pissed.. i am not by any infiniti dealers, can i get the code read at pep boys or something? Car is running fine.. when will they make a car that explains itself when a light goes on? argh..
Old Jun 12, 2009 | 09:56 AM
G37Sam's Avatar
G37Sam
What mods do you have on your car?
Old Jun 12, 2009 | 10:09 AM
XMMAN's Avatar
XMMAN
no performance mods.. just tint and leds..
Old Jun 12, 2009 | 10:15 AM
Raven's Avatar
Raven
that's your leds' fault, remove them!
j/k
sure you can scan the errors at any service. at least it will give you the understanding if your car is driveable or should be towed
Old Jun 12, 2009 | 10:20 AM
STOOF's Avatar
STOOF
yeah pepboys can scan and clear the code for free.
Is your gas cap tight? lol
Old Jun 12, 2009 | 10:46 AM
Csquared's Avatar
Csquared
did you just recently Fill up your gas? loose gas cap?
Old Jun 12, 2009 | 10:47 AM
majin ssj eric's Avatar
majin ssj eric
^^^Most common cause of a CEL....
Old Jun 12, 2009 | 10:56 AM
Graham's Avatar
Graham
I'm putting my money, on Evaporative Fuel Leak.
And your stupid Service Advisor will only say, "Make sure to tighten your fuel cap."
Like we don't know that already, thanks.
Old Jun 12, 2009 | 11:04 AM
djm17178's Avatar
djm17178
I just had my first engine light come on too - at 473 miles!!!
I was halfway through a tank of gas when it came on last night. I went to Autozone and they said it was a "Small leak in the emissions system". I checked the gas cap, but that wasn't it. Anybody have any ideas? No mods, and my dealer is 50 miles away. It doesn't sound serious so I think I'm going to keep driving it until I am up around the dealer for work...
XMMAN's Avatar
XMMAN
no im actually running low on gas (1/4 tank)
Old Jun 12, 2009 | 11:08 AM
Graham's Avatar
Graham
Tell the dealer to contact infiniti tech support line to fix the problem, otherwise you'll do the same thing as me, go in 5 times for the same thing over and over again. BTW, no guarantees it will work either. Just the last time they fixed it it stayed off for a longer period of time.
Old Jun 12, 2009 | 11:11 AM
djm17178's Avatar
djm17178
Did you get the same error? What did infiniti tech support tell them it was?
Old Jun 12, 2009 | 11:36 AM
Graham's Avatar
Graham
They replaced the filler neck piece of the gas tank, and replace the fuel cap I believe.
Old Jun 12, 2009 | 11:53 AM
djm17178's Avatar
djm17178
Ahhh... I'm assuming they don't carry that stuff in stock. I really don't want to have to leave my car up there....
Old Jun 12, 2009 | 12:30 PM
kieranlavin's Avatar
kieranlavin
Check the code. Follow this procedure but, when the light starts blinking, instead of releasing the gas pedal and putting it back down, JUST release it. Count the blinks. Should be in series of fours so (for a 2481 for example) you'll have for example 2 blinks, pause, 4 blinks, pause, 8 blinks, pause, 1 blink, and then it'll give you another code or repeat. Do that (and it really is about timing to get it properly) and report back what codes you pull and someone can look it up in the FSM
