Rear active steer
Old Nov 25, 2008 | 06:02 PM
jharc's Avatar
jharc
Rear active steer
Does anyone think that rear active steering should be the deciding factor in buying my G Coupe, i really want it but do i need it?
Old Nov 25, 2008 | 06:15 PM
elite's Avatar
elite
Have you read up on it?
The four-wheel active steer option includes a computer controlled variable ratio steering gear in front that tightens up the steering ratio during slow speed maneuvering. Below around 35 miles per hour, the steering is quite fast so that I rarely had to reposition my hands on the wheel while driving on twisted country roads. Bring it up to highway speeds and the steering ratio gets less aggressive so it doesn't feel too sensitive for relaxed cruising.
On this option package, not only do the front wheels steer, but the rears do as well. At slow speeds, the rear wheels turn opposite the fronts which tightens the turning radius and allows you to park in a tighter space, or make a U-turn without needing to reverse. On the highway, the rear wheels steer at a small angle in the same direction as the front wheels, which improves highway stability.
To give you an example, the base model with 18 inch wheels and tires has a 16.4 to 1 steering ratio which will give you 3 full turns of the steering wheel lock to lock. If you order the Sport package, you get the 19 inch wheels and tires and a ratio of 14.7 to 1. This will get you 2.7 turns lock to lock. Now, if you order the active steering (which is only available if you also order the Sport Package) you get a variable ratio that goes from 11.9 to 1 to 14.3 to 1 and 2.2 turns to 2.6 turns lock to lock.
It's more popular with the Canadian Boards.
MaxToTheG37's Avatar
MaxToTheG37
Super Moderator w/ Boost
Nope... not the deciding factor... buts its nice to have...
do a search... there is a few of these threads already created...
Old Nov 25, 2008 | 06:40 PM
jharc's Avatar
jharc
thanks guys
Chris Olson
Dec 29, 2025 07:59 PM
Ryne
Jan 18, 2016 05:39 PM
joeposter
Sep 8, 2015 04:36 PM
mauiwowie
Aug 16, 2015 06:01 PM
