Winter Storage
Old Oct 27, 2008 | 10:56 AM
oooLz's Avatar
oooLz
Winter Storage
Hi all,
Winter is coming around and its time to put the baby G to sleep.
I've never stored a car let alone a G.
Can any one provide some tips? I found this on an S2K forum:
1. Change the oil and filter, unless you are still within the “break-in” period (pre-3,750 or 7,500 miles). Let the engine run for a while.
2. Fill the gas tank to the top. You want the smallest air gap in the tank because temperature changes will cause condensation in there. The consensus seems to be that fuel stabilizers are NOT necessary.
3. Wash and detail the car including treating the inside vinyl and leather. Drive the car to remove any standing water that gets trapped in the nooks and crannies and to remove moisture in the exhaust and engine.
4. Run the air conditioner for about 10-15 minutes on the last drive to ensure all the moving parts get the lubricant circulated so the seals don’t dry out.
5. Clean out the interior really well, leaving nothing behind. Check all small compartments, ashtray, etc. Mice getting into the car can eat wires, vinyl, leather, carpet, etc.
6. Apply a silicone spray lubricant to door and trunk seals to minimize sticking.
7. Stuff a rag into the airbox intake to keep mice out.
8. Stuff a rag into the end of the tail pipes to keep mice out.
9. For those who are paranoid about mice, place several mothballs around the interior, placing them on small paper plates so they are not in contact with the car. Place several mouse traps around the car, bait them with peanut butter.
10. Spray lightly a bit of Febreeze (fabric deodorizer) on both floor mats.
11. Make sure the window wash fluid is the anti-freeze kind and not straight water.
12. Check the anti-freeze and adjust if needed.
13. Top off any other fluids under the hood.
14. Keep the CV joints in good shape by keeping the CV boots in good shape. When stored, the boots do not go through a regular routine of being flexed and this may cause them to develop a sort of “memory” such that when you drive it in spring, it may aggravate the start of cracking. You might want to consider going under there and liberally using some “rubber safe” silicone spray and get those (there are 4 on the rear half shafts) babies dripping wet with silicone.
15. Depending on how long you plan to store the car (more than a couple of months), you might also look into an “oil fog spray”. They sell these in auto supply stores. It is an oil mist that comes in a spray can, specially marketed for this application. Just before you put the car to bed, after your last drive, you take off the intake hose to expose the throttle body. You then spray this mist into the throttle body till the car begins to run a bit rough. Stop the spray and immediately shut the car off, replace the intake hose. This will keep a coat of oil film on all the internal engine parts so that the first start of next season will be less metal-to-metal wear.
16. Open up the battery cells and fill up with distilled water, NOT tap water. Tap water contains impurities that can shorten the life of batteries.
17. Pump the tires to about 45PSI to avoid flat-spotting. Place a piece of scrap carpet or foam insulation under each tire while parked.
18. Support the wiper blade arms with a rag to help maintain the rubber.
19. Put the transmission in reverse.
20. Roll the car ¼ to ½ turn 3 to 4 times per winter to ensure the rotors don’t stick to the pads. Work the pedals.
21. Keep windows down half way to keep condensation and moisture from collecting in the car. Do NOT set the ventilation selector to “re-circulate”. Leaving it selected to “vent/floor” will allow for air to expand and contract in and out of the car.
22. Keep the parking brake off to avoid having the pads rust to the rotors.
23. Sweep the garage floor and lay down a plastic tarp or park the car on linoleum. Concrete can get damp in the winter and if the car sits on linoleum or a tarp it will help to keep most of the moisture away from the car so the underbody does not collect condensation.
24. Disconnect the battery. Some recommend removal of the battery and taking it into the warmth of the heated house. Removing it will completely prevent electrolysis between the thousands of spots in your electrical system where it could occur. If you remove it, do not store it on concrete. Make sure you have the stereo code before unhooking the battery! Buy a “battery tender” which differs from a “trickle charger” in that it knows (has a chip in it) when the battery is fully charged and thus turns itself off. Two sources are: (http://www.griotsgarage.com/catalog.jsp?&SKU=77655 ) (http://canadianbiker.com/tender.html )
25. Put a breathable car cover on.
26. DO NOT start the car unless you are going to drive it. When the car sits, all the oil drains into the oil pan. Starting the car is the hardest thing on the engine. Doing it once in the spring is better than several times throughout the winter.
27. You may want to call your insurance agent to suspend some of your insurance while the car sits in the garage. Rumor has it, if we have a nice day in the middle of winter and you want to take it for a drive you can call your agent and get coverage restored for the day. Call your agent to make sure this is an option with your policy first!
28. In the spring, start it up and let it idle until it's almost warmed up before driving it anywhere and then drive it easy for a couple of miles so your transmission, differential & CV joints can get a good lube "workout".
29. Remove the CD from the CD player. If you have a CD changer, remove the CD magazine.
Just looking for clarifications and thoughts from all the other G drivers
Also i don't my Navi screen to freeze over from the LCD. Any comments?
Thanks! any advice will help!
Old Oct 27, 2008 | 01:40 PM
AndrewDDS's Avatar
AndrewDDS
I've never done the winterization thing either, so my advice is purely my opinion and experience. But I have never had an entire winter where there was standing snow/slush on the roads for an entire month solid. Usually there are a few periods of time here and there between storms where the roads are clear and dry for a day or two. I just get the car out and drive it around for a few hours, avoiding puddles as best as possible.
I have no idea if my logic is right or wrong, but I figure as long as I get the car out once or twice every few months then I'm in the clear.
Old Oct 27, 2008 | 01:53 PM
Lije Baley's Avatar
Lije Baley
DOMO I am so glad I live in California when I read something like this.
Old Oct 27, 2008 | 01:58 PM
aliiin's Avatar
aliiin
BMW Defector
and you're also glad you have a high standard of living over there
Old Oct 27, 2008 | 02:58 PM
AndrewDDS's Avatar
AndrewDDS
Filling my car up for $2.12/gal with 91 octane takes the pain out of the 2 months of snow we get here.
Old Oct 28, 2008 | 10:15 AM
Lije Baley's Avatar
Lije Baley
Central Valley
It's not all LA glitz here. In the Central Valley near Sacramento it's a lot like the rest of country. But, Tahoe is two hours in one direction (where we can "visit" the snow if we wish), the North Coast (Pacific Ocean) is two to three hours in the other direction, while the Napa Valley is 90 minutes (or less) away and Amador Valley in the old gold country with wonderful wineries is an hour from home. And the two-lane, sometimes winding roads to any of those places are an incredible blast in the G.
Best of all, we won't die of exposure if we're outside for a couple of hours in January...
Old Oct 28, 2008 | 08:18 PM
pyro1's Avatar
pyro1
Storing battery on cement is OK, has no effect on battery. I had a Vet for 21 yrs stored every winter in Minn. Don't use moth ***** had mice make nest out of them. I use hot red pepper and spreckled it on the carpet, engine compartment, glovebox and around car. blew off engine and vacummed car in spring. Agree with the rest.
Old Oct 28, 2008 | 08:24 PM
nogoodname's Avatar
nogoodname
thanks for the Most useless comment ever.
p.s: I think those steps are overkill
Old Oct 28, 2008 | 09:14 PM
shumby's Avatar
shumby
i got a 67 comet cyclone. change the oil, full tank of gas add gas stabilizer put on jacks and remove battery. Change oil again after storage in spring.
Old Oct 29, 2008 | 01:34 AM
Lije Baley's Avatar
Lije Baley
Wait a minute... this guy is calling someone else's post the most useless ever???? WTF!!! I have to put him/her/it on my ignore list NOW!!!
Old Oct 29, 2008 | 09:41 AM
nogoodname's Avatar
nogoodname
^^ go ahead and add me to the ignore list plus everyone one else on this thread here...lol
Old Oct 29, 2008 | 10:02 AM
stylez09's Avatar
stylez09
What is the least amount I should drive my car during the winter to not have to worry about all these winter storage rules? And when I do drive it..should I drive it for a certain period of time?
Old Oct 29, 2008 | 10:03 AM
nogoodname's Avatar
nogoodname
nah nah, just drive it once/twice a month on a clear day.
clear as in clear roads...lol
Old Oct 29, 2008 | 10:07 AM
CHI-TOWN G37's Avatar
CHI-TOWN G37
I "store" my G as well, which means it gets driven every couple of weeks as long as there isn't snow on the road. I light up the summer tires for a block or so with the VDC off just to wake up the neighborhood
If I had to do all that winterizing stuff in that first post winter would be over before I got to half of it. I'm basically lazy.
Old Oct 29, 2008 | 10:10 AM
nogoodname's Avatar
nogoodname
^^ the list is sooo overkill
