Rear Window Defroster Separating
Old Jan 31, 2024 | 08:10 PM
LuckyJack's Avatar
LuckyJack
Hello.
the defroster has begun separating from the rear windshield. It's still working well enough, but I'd like to fix it if possible before it gets much worse.
Does anyone know if there's a way to repair it without having to replace the whole thing?
Thanks.
Old Jan 31, 2024 | 10:14 PM
Epiphany's Avatar
Epiphany
Is that not poorly done tint peeling? I don't think it's your defroster but the tint itself.
Old Feb 1, 2024 | 09:58 AM
ILM-NC G37S's Avatar
ILM-NC G37S
+1 for window tint peeling. Mine is starting to show signs of failing but it has been 15 years or so...
It is not the defogger grid.
Old Feb 1, 2024 | 10:22 AM
LuckyJack's Avatar
LuckyJack
Thanks for identifying the actual problem. The tint is the original so it's about 10 years old. I wonder if it's best to have it just replaced, or if there's some way to re-adhere it, perhaps by applying heat?
Old Feb 1, 2024 | 10:29 AM
Do some research for a local tint shop. You're in Mass, so you should have lots of options. Most tint shops are really professional and skilled. It might not seem like rocket science, but there is a skill to doing this, and it's all the shop does every day. And if a shop does the work, they'll guarantee the defogger won't be damaged.
Old Feb 1, 2024 | 10:40 PM
Epiphany's Avatar
Epiphany
It shouldn't look like that in 10 years if it's OEM. From factory glass is usually tinted internally instead of a film. It won't be able to be reattached unfortunately, as Rochester says you'll want a shop to redo it. It would probably be cheaper than you'd expect too.
gavinduprat
Apr 25, 2026 05:34 PM
hkbazzi
Jul 5, 2021 05:13 PM
Kboyd
May 9, 2018 02:51 PM
LarryG
Nov 15, 2015 07:02 PM
prutkows
Apr 3, 2008 01:34 AM
