Constant beeping now
Old Apr 28, 2019 | 11:20 PM
teahead's Avatar
teahead
I disconnected the battery for some wiring stuff.
After I reconnected, now I get a beep every 10s. Sounds like it's coming from the rear left quarter panel.
Anyone else have this issue?
Old Apr 29, 2019 | 09:44 AM
kiseliok's Avatar
kiseliok
G37 Community Team
Do the full open / close cycle and it should go away. I think every vert owner has posted about this at some point.
Old Apr 29, 2019 | 11:30 AM
ikbb's Avatar
ikbb
i had the same issue, and opening and close did not solve the issue.
i had to clear the B1762 code, and then the beep went away.
B1762 - ROOF STATE (incorrect)
but yes, the beep is because the roof operation did not completely complete its operation.
Old Jun 4, 2021 | 06:15 PM
teahead's Avatar
teahead
I got this again. Nissan Dealer has no clue how it got there.
Anyone else get this and discover what the REAL issue was?
teahead's Avatar
teahead
B1762 that is.
Old Jun 4, 2021 | 07:21 PM
stugots81787's Avatar
stugots81787
Cycle the top it stops the beeping. Car has to reset.
Old Jun 4, 2021 | 09:54 PM
kiseliok's Avatar
kiseliok
G37 Community Team
Yep, beeping usually stops after cycling the roof. No idea why it starts in the first place though.
Old Jun 4, 2021 | 10:39 PM
stugots81787
Exactly usually what I’d do to not have to cycle the whole thing again even though the roof is closed I’d hold down the close button you hear some gears move and then the beep goes away but if that doesn’t work for you cycle it open then cycle close and it should make it stop.
Old Jun 14, 2021 | 08:27 PM
RANDY350Z's Avatar
RANDY350Z
It could also be your battery needs to be replaced. I had this issue after the battery would run low even after starting it. Once it charged up I would cycle the top and it would go away. I wasn't daily driving it. I replaced it with a yellow Optima, it beeped again and I cycled it and no issues.
Old Jun 15, 2021 | 06:47 PM
stugots81787
A dying battery causes a whole slew of issues in this car. You are absolutely right.
Papa 10
G37 Convertible
12
Apr 13, 2023 10:15 AM
3BOSH
G37 Convertible
Nov 3, 2020 01:38 PM
jms515
G37 Convertible
Oct 21, 2018 12:00 PM
SilverLeaf
G37 Convertible
43
Jan 13, 2016 11:41 PM
spitfire9200
G37 Convertible
Jan 30, 2012 12:16 PM
