Bad MPG!
Old Dec 26, 2018 | 11:57 PM
llebcire's Avatar
llebcire
Originally Posted by NamTDuong
Hello Everyone,
An update on the situation:
-Currently average 15.5 MPG in the city of Chicago, IL., some highway
-Firestone Firehawk Indy 500s around all 4 a month old
-Berks HFC
-TopSpeed Pro 1 Exhaust
-Stillen CAI
-No tune or other mods
-No codes, TPMS, or other dash lights.
-Only use Shell V-Power Gasoline
Would that be about the correct MPG that it would be at?
Fueleconomy.gov rates the 2013 G37x Coupe @ 18 in the city, this is under simulated conditions with a fully warmed engine between 68 - 86 degrees - certainly warmer than now in Chicago.
With a G37x Sedan (auto) in IA, similar weather, I've been getting 13.9 - 14.9 with mostly city driving (premium 91 octane). From what I've read, this is fairly common MPG.
-Eric
Old Dec 27, 2018 | 02:03 AM
User 110921's Avatar
User 110921
If you guys could provide some insight on this too! Thanks.
https://www.myg37.com/forums/tsb-tec...endations.html
Old Dec 27, 2018 | 10:39 AM
telcoman's Avatar
telcoman
Hello all,
I have a 2013 Convertible base with no aftermarket modifications. I am not an erratic driver and do not race my G37. The current issue is that the MPG counter show averages of lower than 10MPG. I had reset the counter but it still shows the low average. I would appreciate any advice. Thank you!
Either it is your driving style, warming up your vehicle, short trips, etc or you have something wrong.
You cannot expect decent MPG on any Infiniti unless you start with a full tank, set your odometer to zero,reset the vehicle computer, drive 350-400 miles on a freeway, turnpike, etc, refill the tank and divide the gallons to fill up into the miles traveled.
The math calculation will be close to the vehicle computer MPG readout.
My recent round trip with my Q70 from NJ to Florida. Ten fill ups total. Four fill ups on the way down, two fill ups for local driving while in Florida, and four fill ups on the return to NJ
Below are the actual math calculations for the ten fill ups.
All gasoline fill ups were using regular 87 octane
24.98, 25.45, 22.88, 25.71, 17.34, 16.62, 22.95, 22.93, 20.2, 25.44
Mileage dropped on local Florida driving as well as slower driving in rain with traffic backups . The 20.2 MPG result was from driving home in a raging North Carolina Snow storm.
I'm on my third Infiniti and have received similar results on the road all using regular 87 octane. I do not use cruise control as it lowers MPG by 1-2 MPG. Tires are inflated to 35lbs when cold
Telcoman
Old Dec 30, 2018 | 03:17 PM
slartibartfast's Avatar
slartibartfast
I drive mainly short trips and consistently get 20 to 22 mpg. Only on the track do I get 9 mpg. Look at catalytic converters, O2 sensors or fuel leaks.
Old Dec 31, 2018 | 08:14 PM
zarandallz's Avatar
zarandallz
The best mileage I get on my 2010 Anniversary Ed Convertible G37 is 20.2 mpg. When the accelerator pedal finds its way to the floor, I get closer to 19 mpg. If I want efficiency, I drive my Model S. If I want classic style I drive my G37.
coastalsquirrel
Dec 13, 2014 08:09 PM
deep007
Mar 8, 2013 01:42 AM
PR_G37
TSB - Technical Bulletins
Aug 23, 2011 04:22 PM
8lackMacObs
General Tech Questions
Apr 11, 2011 11:01 AM
