Trunk hinge bumper pad
Old Jul 18, 2018 | 05:26 PM
G8RDave's Avatar
G8RDave
Has anyone had to replace the little rubber pads that cushion the trunk hinge that opens when you open or close the roof? I can't find the part number. Any idea of where I could get one other than the dealer?
Both of mine are completely destroyed/dissolved.
Old Jul 19, 2018 | 02:23 PM
G8RDave's Avatar
G8RDave
So I never found the Infiniti part number, but I did discover that a solid rubber plug from Home Depot or Lowe’s, 1 inch in diameter and 3/4 inch in length, fits perfectly. It is a very snug fit into the cup so it won’t fall out. The top is much smoother in operation now.
Old Jul 19, 2018 | 11:10 PM
kiseliok's Avatar
kiseliok
G37 Community Team
Thanks for posting this! I'll have to take a look as the final trunk closing has been a bit louder lately.
Old Jul 20, 2018 | 10:52 AM
G8RDave's Avatar
G8RDave
These bumpers are actually in use when the trunk opens backwards to let the roof into or out of the truck They cushion the stop when the trunk is in full open position.
Old Jul 21, 2018 | 12:12 AM
kiseliok's Avatar
kiseliok
G37 Community Team
Which position should the roof be in to replace these?
Old Jul 21, 2018 | 02:39 AM
G8RDave's Avatar
G8RDave
The roof needs to be closed in order to replace the bumpers. Actually, now that I think about it, you might be able to do it with the roof open (folded up in the trunk). Those hinges are outside of the roof mechanism, I think.
Old Feb 8, 2019 | 01:17 PM
teahead's Avatar
teahead
You got an AFTER picture w/them installed?
Old Jul 3, 2019 | 03:34 PM
myg37gsg's Avatar
myg37gsg
Trunk Hinge Bumper Part #844A9-JJ51B
My trunk hinge bumpers are also disintegrating as described by G8RDave.
I found the part number for the Trunk Hinge Bumper, part #844A9-JJ51B. Infiniti charges $203.60 each. That's crazy!
I will investigate the solid rubber stopper from Home Depot or Lowe's. Thanks for posting this solution. GR8Dave, How is solution working for you?
Old Aug 9, 2019 | 07:06 PM
gwurst's Avatar
gwurst
I created a model of the bumper if you have a 3D printer and some flexible filament like TPU:
https://www.thingiverse.com/thing:3800722
Old Aug 9, 2019 | 08:22 PM
myg37gsg's Avatar
myg37gsg
gwurst,
Awesome. Thank you!! What density of TPU material do you recommend using for this part. I don't personally have a 3d printer but understand that there are businesses like Staples and The UPS Store that offer 3d printing services.
Have you or someone you know successfully used this 3d printer object in a G37 convertible?
Old Dec 1, 2019 | 09:28 AM
Paul Prachyl's Avatar
Paul Prachyl
I used this, https://www.homedepot.com/p/1-in-x-2...8248/204273790, fits well and has the same texture (springie-ness) as the original.
rsingerG37
May 8, 2017 08:28 PM
rsingerG37
Aug 2, 2016 08:21 PM
oldschool33
General Tech Questions
Feb 2, 2014 01:55 PM
r6rider211
Car Care & Detailing
May 25, 2011 12:43 PM
billyg
Jun 29, 2010 07:57 PM
