Hydrauling Pump/Line replacement
Old May 15, 2018 | 04:26 PM
pmagee317's Avatar
pmagee317
Question Hydrauling Pump/Line replacement
I have a 2010 G37 convertible. I had two hydraulic lines with leaks. Quoted $9800 from the dealer and that's not happening so i started looking into my options. I replaced the lines and put everything back together, but the top still wont open. The windows open, the parcel shelf goes down. Then the pump runs for 20 or so seconds and it stops. Same as it did when it leaked. My assumption is that i either have a bad seal on one or many of the lines at the pump or to much air in the lines for the system to operate. Since the manuals are no longer available thanks to Nissan's legal team I was wondering if anyone could share some procedures or tips.
Also does anyone know what the brass hex bolt on top of the pump does? All i can tell you is if you turn it to hard you will ruin your pump. that lesson cost me $500 and i'm hoping to reduce the cost of my education.
Thanks,
Patrick
Old May 15, 2018 | 05:14 PM
kiseliok's Avatar
kiseliok
G37 Community Team
Ouch. Hopefully you'll get it figured out.
Old May 15, 2018 | 07:20 PM
FSUGrad90's Avatar
FSUGrad90
Originally Posted by pmagee317
I have a 2010 G37 convertible. I had two hydraulic lines with leaks. Quoted $9800 from the dealer and that's not happening so i started looking to my options. I replaced the lines and put everything back together, but the top still wont open. The windows open, the parcel shelf goes down. Then the pump runs for 20 or so seconds and it stops. Same as it did when it leaked. My assumption is that i either have a bad seal on one or many of the lines at the pump or to much air in the lines for the system to operate. Since the manuals are no longer available thanks to Nissan's legal team I was wondering if anyone could share some procedures or tips.
Thanks,
Patrick
Patrick I posted this on another thread so I thought I would again for you as I saw this on Ebay Not sure if this is what you need
https://www.ebay.com/itm/INFINITI-2009-2013-G37-CONVERTIBLE-TOP-PUMP-MOTOR-WITH-LIFTERS-97091-JJ50A/162528134095?ssPageName=STRK%3AMEBIDX%3AIT&_trksid =p2060353.m1438.l2649
Old May 17, 2018 | 12:34 PM
pmagee317's Avatar
pmagee317
Thanks, I saw that. I have already replaced all of the defective parts so I'm not looking to buy them again.
~P@
My part sources for this project so far:
http://www.cabriolethydraulics.com/ replacement hoses approx $125/hose
https://www.tophydraulicsinc.com/en/
re manufactured pump: $820 (includes pump, $300 core deposit, shipping)
Old May 23, 2018 | 10:52 PM
pmagee317's Avatar
pmagee317
Update: turns out I was just suffering from rectal-cranial inversion. I had the solenoid wires on the top of the pump on backwards. Should have taken more pics during the disassembly. It will still need to go to the dealer for a re-learn, but with that I'm out $1750 much better then the $9,800 I was quoted to fix it.
Old May 23, 2018 | 11:02 PM
kiseliok's Avatar
kiseliok
G37 Community Team
Well done, sir!
Old May 24, 2018 | 01:57 PM
Tucsontripleb's Avatar
Tucsontripleb
Great job! That is encouraging for those of use who can't dole over $10k to repair...and don't have an extended warranty that covers the top. Thanks for sharing!
Old May 24, 2018 | 02:34 PM
pmagee317's Avatar
pmagee317
Thanks
I "never" buy warranties because I prefer to do my own repairs. I did with this car because I figured if anything went wrong with the top I'd be screwed. Well wouldn't you know it the warranty doesn't cover "fluid leaks" so it didn't help after all. Oh, well live and learn..
~P@
Old Jun 18, 2018 | 11:26 PM
NewGVert4me's Avatar
NewGVert4me
I get the DIY thing. I enjoy turning a wrench now and then myself. I pulled and replaced the entire suspension on our '93 Miata as well replaced the radiator. THAT car is very simple to work on - being 25 years old and all. As for my G, other than the air filters and cabin filter ( which was a pain to replace compared to my M35) along with the brake pads and rotors, there aren't many things I'm capable of wrenching on my own - especially anything related to the top. For that reason, a warranty made sense for me.
solopresident
49
Oct 11, 2013 01:16 PM
JEBperformance
Brakes/Suspension
30
Apr 2, 2012 11:29 PM
CharlieMac646
Dec 10, 2011 09:59 AM
Q8y_drifter
14
Jun 14, 2010 06:59 PM
