Trunk open warning during convertible opening
Old Jul 26, 2017 | 08:41 AM
Qusai Rayyan's Avatar
Qusai Rayyan
Hello
I have g37s convertible , after i parked it in the direct sun for 10 days the convertible is not opening and i realized that there is something wrong with the balance of the convertible. Please check below photos and advice what i should do
Leftside(driver side)
Rightside(passenger side)
Old Jul 26, 2017 | 01:51 PM
q-style's Avatar
q-style
i've heard theres a temp gauge on the hydraulic pump that when it reaches a certain temp it does not function.
https://www.myg37.com/forums/g37-con...tible-top.html
Old Jul 26, 2017 | 05:13 PM
Qusai Rayyan
I know this , and usually after the tempreture goes down the pump will work normally .
But the plastic plate that will cover
the hard top is not moving and it is dissambled from the hydraulic system because of the direct sun . I dont know how that possible but i am belive that there is a glue between the metal plate and platsic cover
(79906 & 73663ZF)
G37s convertible original parts
Old Mar 1, 2018 | 12:36 PM
jgold92's Avatar
jgold92
Did you ever get this fixed?
