Broken seat belt loop
Old Dec 6, 2014 | 09:29 PM
James2008's Avatar
James2008
Smile Broken seat belt loop
I have a 2009 G37S vert and my seat belt loop is broken as seen in the photo.
Broken seat belt clip by Vackovich, on Flickr
What are my options to get this fixed?
The dealer stated it would require a whole new seat cover with a very expensive cost.
Any help would be appreciated.
Thanks.
Old Dec 6, 2014 | 09:52 PM
gsqrd's Avatar
gsqrd
wish i had answer
My 2012 Vert failed similarly. Was warranted. Fix was new seat cover as you said. Maybe a seat cover shop could fix?
Old Dec 7, 2014 | 11:23 AM
weird60625's Avatar
weird60625
I got same issue with my 09 vert also , got it fixed under warranted , shop around with some body shop see if they can fix that .
Old Dec 10, 2014 | 08:58 PM
bschurr's Avatar
bschurr
If not an auto body shop or custom interior place, a shoe repair guy should be able to easily fix that specific portion of the snap...
Old Dec 14, 2014 | 12:42 PM
_tjp_'s Avatar
_tjp_
Yes, as the others stated, go and find a local car upholstery shop in your area. I had a seat belt guide replaced in my BMW Z3 and the upholstery shop did a great job and they did it in less than an hour.
Old Dec 15, 2014 | 08:28 AM
Pnrymmf's Avatar
Pnrymmf
you might try even a alterations shop if it is just the snap needing replaced. not the same but they replaced some on a coat i had.
Old Dec 16, 2014 | 01:20 PM
James2008's Avatar
James2008
Unhappy Infiniti reply to the issue
I contacted Infiniti regarding this defective design of my seat belt loop. There reply was "..this is not a wantable position for Infiniti and the seat belt is still functional".
My 09 convertible has 33k miles and this poorly made seat belt loop failed. It is not reassuring to see that Infiniti weaseled their way out of standing behind their product.
Thanks to the forum members for your advice as I will now be seeking a custom upholster solution.
Old May 14, 2015 | 04:34 PM
jbosey's Avatar
jbosey
I am curious did you get this repaired? My leather is not torn but the snap is broken and has come off the leather strap.
Old May 14, 2015 | 04:41 PM
James2008's Avatar
James2008
I found a upholstery place that removed my seat cover and replaced the snaps that were broken on the seat. I am not certain what you would do in your case for the broken snap in the strap. I still think that a good upholster place could remove the stitching, slide a new snap in, and sew it back together without removing the seat cover.
Old May 14, 2015 | 06:22 PM
Redfire32's Avatar
Redfire32
Ginger ninja
Wow a lot of great advice here. My 12 vert failed as well in same spot. Had I known about the options mentioned on this thread 6 months ago I wouldn't have taken some hardcore Leather glue to it and solved the problem myself. But I would think an upholstery guy could still fix it after separating the glue I used from the button. Right??
Old Oct 17, 2015 | 05:18 PM
ironlungs10's Avatar
ironlungs10
I have the same problem on my driver seat. The snap came off with everything else intact. Doesn't really bother me, but I have closed the door on the buckle which caused a some scratching in the door seam. 😠
I have no idea how this one happened, but on my rear seatbelt, where the seat belt comes out, the plastic piece just came off. Nobody even sits back there!! Anyways, cosmetic problems that don't bug me enough yet but I'll soon take care of these.
Old Oct 18, 2015 | 01:47 PM
Blake008's Avatar
Blake008
Same prob. 2011 'vert. Aggravating as hell.
Old Oct 19, 2015 | 05:16 PM
rdog's Avatar
rdog
I have the exact same problem with my 2011. In fact, if I didn't know better, I'd say that you took a picture of my broken strap.
Old Nov 4, 2015 | 08:05 PM
rdog's Avatar
rdog
Do a lot of vert owners have this issue? I am going to apply a fix on mine this weekend. If it works, I'll post an update and what I did. Didn't know if it would be of value if this is an isolated issue.
Old Nov 4, 2015 | 10:18 PM
gsqrd's Avatar
gsqrd
Yes
Happened to my 2012. fixed under warranty. Seen it mentioned a lot on this site. Please post results.
