radio reception w/ Spoiler antenna
Old May 4, 2011 | 11:34 AM
wreckeds2k's Avatar
wreckeds2k
is it me or is the reception off a little with the low profile antenna ?
Old May 4, 2011 | 12:02 PM
bschurr's Avatar
bschurr
Wha?
Are you having issues with AM/FM or XM?
Do you have the OEM spoiler? or the standard antenna on the trunk lid?
Old May 4, 2011 | 12:21 PM
Stillnorth's Avatar
Stillnorth
I've noticed that my "smurf" antenna has caused a real decline in FM reception. AM and XM seem largely unaffected.
Old May 4, 2011 | 12:26 PM
bschurr's Avatar
bschurr
The screw in antenna (stick or Smurf nubbin) only affects AM & FM (and you typically dont even require an antenna for AM due to its operating frequency). Satellite radio antenna is the base unit under the screw in post.
If you get the OEM rear spoiler, the AM/FM antenna is relocated to an area within the spoiler itself and the current Satellite antenna is replaced with a slightly smaller unit with a new cover that deletes the screw post.
Old May 4, 2011 | 01:52 PM
Fezzik's Avatar
Fezzik
I had the smurf and currently the spoiler. I am in chicago and I noticed a loss of FM with the smurf, and the spoiler is about the same as teh large bumble bee antenna.
Old May 4, 2011 | 08:56 PM
cvipgo's Avatar
cvipgo
I thought you recently had the OEM spoiler kit installed and is causing reception issues? Is it AM or FM or Satellite?
Old May 5, 2011 | 07:42 AM
bschurr's Avatar
bschurr
If you are getting poor FM with the newly installed OEM Spoiler then I suspect that you didnt ground the antenna properly. One of the 2 holes that you need to drill into the front face of the trunk is used to accommodate a grounding wire for the antenna module in the spoiler. If this wire is not making proper contact with the grounding nut (on the inside of the trunk lid) then you will get crappy reception. In the install instructions there was a step to check the continuity (ohms) of the AM/FM circuit -if this was not validated, I would begin my search there.
Good luck!
Old May 5, 2011 | 12:52 PM
wreckeds2k's Avatar
wreckeds2k
Good luck!
I appreciate it, thats where i will start.
Old May 5, 2011 | 07:22 PM
cvipgo's Avatar
cvipgo
Check all electrical (connectors & ground) connection per the Spoiler Installation Instructions.
Old May 19, 2011 | 12:16 PM
ImStricken's Avatar
ImStricken
If anyone needs install instructions i can always email you photo's of the oem install instructions.
New2Infinity
Sep 9, 2015 10:34 AM
GeezerB
Aug 26, 2015 05:16 AM
sharkey
Aug 2, 2015 05:30 PM
amciner28
Jul 15, 2015 09:49 AM
