Wiper arms blocking windshield fluid nozzle
Old Dec 3, 2010 | 06:21 PM
Mike888's Avatar
Mike888
The wiper arms on the driver side seems to be in the path of the nozzle and thus blocks some of the windshield fluid. I have stock wiper blades and was wondering if this is normal on the vert?
Old Dec 3, 2010 | 06:23 PM
RaulGCustom's Avatar
RaulGCustom
SoCal Driven
they should be spraying at the same time the wipers are moving, so it shouldn't matter.
I personally don't use this, its pretty messy and gets all over the car.
Old Dec 3, 2010 | 07:26 PM
cvipgo's Avatar
cvipgo
this is not normal, I don't have this issue, push your driver side wiper down or have dealer check it out...
Old Dec 3, 2010 | 08:30 PM
Mike888's Avatar
Mike888
The wiper is all the way down. The arm doesn't seem to be bent or anything so I don't understand why its blocking the nozzle. I might visit the dealer next week to see whats going on (hate driving there). Thanks for the reply.
Old Dec 3, 2010 | 08:33 PM
STOOF's Avatar
STOOF
Is it spraying the bottom of the windshield?
Doesnt seem right. Pop the hood and make sure the nozzle is clipped in all the way.
If it is, you can also adjust where the fluid shoots by sticking a pin into the nozzle hole and adjusting it.
Old Dec 3, 2010 | 08:38 PM
cvipgo's Avatar
cvipgo
yes, good suggestions and most likely are the causes..
Old Dec 3, 2010 | 08:47 PM
Mike888's Avatar
Mike888
Well it isn't spraying the bottom of the windshield, its spraying the same height as the one on the passenger side. It seems that the driver side wiper arm ( the metal piece) is SLIGHTLY higher than the arm on the passenger side, so it blocks some of the windshield fluid. Maybe I'm just being paranoid since it's my first vert and only a month old. I will try adjusting the nozzle tmr to see if it helps, thanks for the suggestion.
Old Dec 3, 2010 | 08:52 PM
cvipgo's Avatar
cvipgo
Congrats on your first vert... you will get most of issues resolved here in this forum with some of the most knowledgeable owners.
Old Dec 3, 2010 | 09:19 PM
Mike888's Avatar
Mike888
Thanks, I'm very happy to have found this forum especially since my knowledge on cars is limited. Everyone on here seems very friendly and eager to help.
vamarris
Dec 9, 2018 11:10 AM
mcgrible
MEDIA SHARE
Oct 13, 2015 10:42 PM
Allboutcali
Sep 26, 2015 03:43 PM
Victory
Sep 18, 2015 06:57 PM
