aggresive driver concern
Old Jun 30, 2010 | 09:50 PM
  #31
Namir's Avatar
Namir
Nobody is implying that you need to baby a car to preserve warranty coverage. But the other side of that coin is that you can't abuse it either. Any type or amount of racing is going to be considered abuse. This is plainly stated in your warranty (that most seem not to have read).
Can you point me in the right direction? I want to read the clause about racing but I don't know where to find it.
Old Jul 1, 2010 | 08:24 AM
  #32
soundmike's Avatar
soundmike
Infiniti Ownership | Vehicle Warranty | Infiniti USA
As the vehicle owner, you should also be aware that Nissan may deny you warranty coverage if your vehicle or a part has failed due to abuse, neglect, improper maintenance or unapproved modifications.
Old Jul 1, 2010 | 08:26 AM
  #33
soundmike's Avatar
soundmike
Also, FWIW, you need to check with your insurance policy as well for any coverage when using the car at any type of track. Usually, timed-events disqualify you whereas non-timed events like HPDE or classes are okay. For timed-events, the track you're on will usually offer coverage for that day, for a minimal fee.
Old Jul 1, 2010 | 12:45 PM
  #34
I have an '08 models so I looked in the warranty information booklet from that year, soundmike linked to them if you don't have it downloaded already.
From page 6:
WHAT IS NOT COVERED
DAMAGE, FAILURES OR CORROSION DUE TO ACCIDENTS,
MISUSE OR ALTERATIONS
This warranty does not cover damage, failures or
corrosion resulting from:
• Accident, theft, fire, driving through water
(including engine water ingestion) or misuse,
which includes, but is not limited to, racing of any
sort whatsoever. (Proper use is outlined in your
OWNER’S MANUAL.)
• Alteration, tampering or improper repair.
• Installation of non-Nissan approved accessories
or components.
• Improper installation of any Nissan approved or
aftermarket accessory or component.
• Glass breakage, unless resulting from defects in
material or workmanship.
• Normal wear and tear, including dings, dents,
chips or scratches.
There's also several references in the tire warranty sections of each manufacturer and the final reference on page 47. You can do a find for the word "racing" to see them all.
Old Jul 19, 2010 | 06:14 PM
  #35
Beer Magazine's Avatar
Beer Magazine
Originally Posted by Mike
Fast synchro wear + analysis of trans fluid is pretty conclusive evidence of hard driving. Unless the synchros literally fell apart or disintegrated, the signs would indiciate (escessively quick) wear and tear.
Yes, the dealer has no incentive to turn the warranty work away. Most likely, NNA was consulted and NNA decided to turn down the work; that is the case with most of the local nissan/infiniti dealers when they're not sure if the work will be reimbursed.
The dealer DOES have incentive to turn work away because if they perform the work and the manufacturer doesn't approve...they DO NOT GET PAID.
Plus all that counts in surveys and such.
Old Jul 19, 2010 | 06:45 PM
  #36
Mike's Avatar
Mike
So don't do the work until it's approved. Cover your bases.
Upscale Speed
Dec 24, 2015 12:00 PM
EnYcee-G
Oct 4, 2015 09:27 PM
SpeedBallDEVIL
Oct 2, 2015 11:20 PM
dedmanchan
Sep 24, 2015 11:25 PM
