Computer People!!!
Old May 10, 2006 | 10:39 AM
JEVERYDAY's Avatar
JEVERYDAY
Originally Posted by Foo_G
is not meeting the EULA or HCL?
Is the windows XP cd a retail cd or an oem cd from dell?
This is normally the problem... Had that problem alot in my technician days.
Old May 10, 2006 | 03:34 PM
_jb's Avatar
_jb
Originally Posted by audiblemayhem
well its not a dell cd and its not a store bought cd, but it has worked many times with my same exact laptop and also on my desktop.
That narrows down the choices...
XP is designed to be installed once and authenticated to that computer once. Microsoft has been increasing its efforts to strengthen its authentication program. They are very serious about it. They are much more serious about authentication that they are about fixing the bugs in Windows, unfortunately.
I did a quick Google search on the error you mentioned and most people reported the problem to be associated with dubious installation CD disks.
Old May 10, 2006 | 04:48 PM
dabomb's Avatar
dabomb
FGC Central Florida BOD
true but this cant be checked during install. If he had the problem 128days after the install then I would say its an authentication problem.
I would first say its a bad CD. it can look good but if something that early is burned out on it then it will cause the whole installation to crash.
Second possibility is bad hardware, definately not limited to harddrive
Old May 10, 2006 | 05:17 PM
Foo_G's Avatar
Foo_G
From: Universe.Milkyway.Solarsystem.Earth.NorthAmerica.USA.FL.Tampa
I have had laptops overheat during istall and cause the optical reader to flake out. Install is very resource intensive I was able to perfmon an isntall using VMWARE ESX virtual center and MS puts the tang to the ram and cpu.
I'd say if it feels hot put some spacers under each corner and run a fan over the laptop during the install to see if it helps. It cold simply be a case of thermal degeneration.
Old May 10, 2006 | 07:02 PM
Audible Mayhem's Avatar
Audible Mayhem
Performance Factory
well i got a start on it today, i sucessfully installed 98SE... lol
maybe it will allow me to upgrade. that is the plan so far
Old May 10, 2006 | 07:21 PM
Audible Mayhem
Performance Factory
ok so i thought 98 SE would work correctly. nope.
and XP wouldnt install over top of it. so i am back to square one.
Old May 10, 2006 | 07:31 PM
Foo_G's Avatar
Foo_G
Just dont fool with ME there are no upgrade paths from me. In order to upgrade from 98SE iirc you ned the xp upgrade cd not the full.
Old May 10, 2006 | 07:43 PM
_jb's Avatar
_jb
I understand what you're saying. I doubt any of us could write code to "phone home" during a windows install... and why would it just start doing it now... after all these installs...
Old May 10, 2006 | 08:01 PM
Audible Mayhem
Performance Factory
i already tried that...
Old May 10, 2006 | 08:23 PM
lawrence's Avatar
lawrence
try an external cd drive , or copy cd onto hard drive and install from that directory.
if has a hard time copping from cd, that is most likly the problem.
Old May 10, 2006 | 09:22 PM
Audible Mayhem
Performance Factory
thanks man i willl try that right now...
Old May 10, 2006 | 09:42 PM
cj350's Avatar
cj350
bring it to gainsville and i will have my friend look at it if its not done by then...... He builds computers
Old May 11, 2006 | 06:14 AM
Audible Mayhem
Performance Factory
thanks bro. hopefully i will have it done today when i get off work. we will see....
conkus805
ECU Tuning / Dyno Data
46
Nov 19, 2015 07:49 PM
2K1 6T8
Oct 6, 2015 07:40 PM
mjnoles1
Oct 4, 2015 10:27 PM
VIVID
Sep 27, 2015 09:45 AM
