Oil Experts
Old Nov 22, 2005 | 09:37 PM
g8tor20's Avatar
g8tor20
FGC's official flip flopper
Oil Experts
Well....I am back to stock as I took the bumper and side skirts back off so that they can be repainted. While I was down there, I checked out my oil filter and oil lines and saw some oil around the oil filter itself and around the piece and bolt to the left of it. It didnt seem to be dripping on the ground nor on the underneath of the car. But lemme know what you all think as I have never changed my own oil so I am not sure if this is normal or not. As always..excuse my ignorance.
TIA
Old Nov 22, 2005 | 09:47 PM
neffster's Avatar
neffster
The oil on the pan is from where they drained your oil the last time. Right when you remove the plug, if you're not fast, the oil gets on the oil pan.
The oily filter doesn't look good. I wonder if they REUSED the old filter? Who did your last oil change?
Old Nov 22, 2005 | 09:54 PM
g8tor20's Avatar
g8tor20
Ocala Nissan. It was my $70 Mobile 1 synthetic oil change a few weeks back.
Old Nov 23, 2005 | 08:24 AM
LokeyInfiniti's Avatar
LokeyInfiniti
It is very common to have some residual oil left in those two areas after an oil service. For the most part, the technician usually wipes that off but from time to time it may be missed.
I would recommend checking the oil filter to be sure it is tight and that would be about it. If they "double-gasketed" your oil filter, it would be leaking fairly heavily (this happens when the old filter is removed and the o-ring seal sticks to the sealing surface, is not noticed, and the new filter and o-ring are installed on top of it creating a leak).
Old Nov 23, 2005 | 08:30 AM
turbomaxima's Avatar
turbomaxima
my guess is they didn't use a new crush washer on the oil filter.. the oil around the drain plug is typical of a careless clean-up after draining.
if you were leaking oil, you would know; the smallest leak would be exacerbated immediately under pressure.
Old Nov 23, 2005 | 08:35 AM
g8tor20's Avatar
g8tor20
I figured it was just a rush job by Nissan. My oil level was good and I felt no dripped oil below the pan or filter. Just had to be sure and post it up. Thanks guys for the responses.
Old Nov 23, 2005 | 11:40 AM
neffster's Avatar
neffster
Is that a hairball dryhumping the ground in your avitar there Jason?
Old Nov 23, 2005 | 11:44 AM
turbomaxima
umm, that's meatwad of course..
and isn't it an avatar?
Old Nov 23, 2005 | 11:49 AM
g8tor20's Avatar
g8tor20
Todd, you dont know about meatwad? Its a cartoon called Aqua Teen Hunger Force. You ought to show it to your little girls. Its family entertainment at its best
Old Nov 23, 2005 | 01:16 PM
Chucky
Guest
Posts: n/a
another good kid friendly show is "Drawn Together"... my 4 year old loves it!
J/K
Old Nov 24, 2005 | 09:30 AM
Meatshackle's Avatar
Meatshackle
Yeah Todd, duh. Everyone knows what a meatwad is. And the only thing that can defeat a meatwad is a meatshackle.
fuzzed
Aug 21, 2020 09:35 AM
amitd79
Feb 21, 2017 04:43 PM
Stevolkz33
May 28, 2016 02:36 AM
Junchao Sun
25
Oct 1, 2015 12:41 PM
Chappedj
Sep 28, 2015 03:20 PM
