KPTechnologies Shift Lights
I know they give a Florida G35 Club discount, did you mention that you were a club member? Also, speak with JOHN OLIVA and no one else. Have him explain the benefit of ordering your kit through them, vs. installing the kit you have. If I'm not mistaken there is NO DIFFERENCE in warranties what so ever.
Well, its me again. I rewired the whole shiftlight according to Daniels instructions. No dice. Pulled orange wire off and touched to ground hoping it would go into programming mode, nope. Changed the signal wire from the brown crank wire to the yellow cam wire, nada. Hooked up the yellow power wire to the black red ignition, good power, light no worky (Light lights up at startup, turns off for a couple of seconds, and then glows dim, won't go into program mode). I think I am left with only one possible answer, I, because fate is always so kind to me, just happened to get the one shift light module with a defect. If Daniel or Kevin have any ideas, I would be more than happy to entertain any possible troubleshooting advice, but I honestly think I need a new box.
FGC Central Florida BOD
dude
i am just as lost as you are.
send kevin a pm and tell him that you need have it shipped back and have im fix it.
sorry i dont know what else
Originally Posted by shooter
dan......can you check pm please?
