KPTechnologies Shift Lights
FGC Central Florida BOD
sure send them to me at daniel.bazley@kptechnologies.com or find me on AIM.
Hey guys,
Dan installed my sunroof mod last night. I think its about the 3rd or 4th he has done. He is getting quick and I highly recommend him if your unsure about doing it yourself. And FGC discounts apply!!!
Thanks again Dan!!!
Thanks again Dan!!!
alright here are some more pin colors for you guys to check to make sure you have the right wire.
pin 10 - white / green
pin 11 - red / white
pin 12 -
pin 13 - brown - crank sensor wire
pin 14 - yellow - cam shaft
pin 12 -
more from kevin
Pin 8 – NC
Pin 9 – NC
Pin 10 – White/Green
Pin 11 – Red/White
Pin 12 – Blue/White
Pin 13 – Brown (Crank angle)
Pin 14 – Yellow
Pin 6 is the start of a row (pins 1-5 are a relay)
Pin 32 (above pin 13) – Pink
All wires match up to what the service manual says they should be.
Hope this helps
guys its not that hard
tom those pics you sent are right on
that wire you have should be the coorect one.
Pin 8 – NC
Pin 9 – NC
Pin 11 – Red/White
Pin 12 – Blue/White
Pin 14 – Yellow
Hope this helps
http://www.kptechnologies.com/forums
Go here (it's a secret world) and post your problems. Be prepared for a rapid fire slew of posts and it might help if you keep your screen name (he he he).
Did it fall back inside of your gauge pod maybe? Did the Power wire come undone?
Originally Posted by Meatshackle
I'm having a serious problem with my shift light. When I first installed it, everything was great. Now I can't see it at all.
im lost
