KPTechnologies Shift Lights
Old Dec 11, 2005 | 04:31 PM
  #211
andy2434's Avatar
andy2434
Chuck,
Thank you . . . Thank you for your DIY link. It was extremely helpful. This link is a must. It takes all of the install uncertainties out of the equation. Especially, for someone such as myself.
Daniel,
The Window Up mod rocks big time. It installs very cleanly and works to a fault. It is a must mod in my opinion. This is how our cars should have come from Infiniti in the first place. Thanks!
Old Dec 11, 2005 | 05:02 PM
  #212
Chucky
Guest
Posts: n/a
Originally Posted by andy2434
Chuck,
Daniel,
No problem. Glad I could help.
Old Dec 11, 2005 | 06:04 PM
  #213
Meatshackle's Avatar
Meatshackle
my shift light is fast blinking when I start my car
Old Dec 11, 2005 | 06:06 PM
  #214
KPierson's Avatar
KPierson
Originally Posted by klg35
who have installed the shift light on their sedans? need to verify if pin #12(crank sensor/light brown wire) is the same as the coupe........if not, which pin #/color wire is the crank sensor for the sedans, specifically 04 6mts...I'll try to dig this info up in another thread as well............thanks.
According to the 04 sedan service manual the crank wire is brown, but its pin 95. There are three brown wires, just like the sedan. However, the service manual only documented the A/T tranny, so it MAY differ to the 6mt. I don't have any info on the 6mt!
Old Dec 11, 2005 | 06:10 PM
  #215
KPierson's Avatar
KPierson
Old Dec 11, 2005 | 07:53 PM
  #216
nsanbyker's Avatar
nsanbyker
Hey guys, I need some help. I'm looking for someone who has an 2003.5 coupe and has installed the shiftlight. I can't get mine to work. Which wires did you 03.5 owners tap into.
Orange goes to blue/yellow vdc wire
Black goes to vdc black
Yellow goes to black wire w/fuse and to ?
Blue goes to ?
I hooked my black/fuse to the cigarette lighter and I can't find a rpm signal wire. Any help is appreciated.
Old Dec 11, 2005 | 07:57 PM
  #217
SFLG35's Avatar
SFLG35
FGC Central Florida BOD
Blue goes to ?
those pictures are from an 03.5 coupe cause thats what i have.
yellow goes to fuse and the other end goes to the black red wire on teh ignition harness.
blue goes to the crank shaft position sensor wire in pin 13
you can also use one of the other wires that kevin has posted on www.kptechnologies.com/forums
i also responded to your questions on there.
Old Dec 11, 2005 | 08:02 PM
  #218
nsanbyker's Avatar
nsanbyker
How do I find pin #13 in the black plastic harness? HOw many down and how many across?
Old Dec 11, 2005 | 08:14 PM
  #219
nsanbyker's Avatar
nsanbyker
Does the power source matter. Is the fact that I am using the cigarette lighter for a power source screwing up the rpm signal?
Old Dec 11, 2005 | 10:35 PM
  #220
KPierson's Avatar
KPierson
No, the power source doesn't matter. In a car, all power originates from the same place. So, as long as your have enough power (which you do) you are fine. Check out the KPtech forum for detailed instructions on how to use a volt meter to find the correct wire.
Old Dec 11, 2005 | 10:51 PM
  #221
nsanbyker's Avatar
nsanbyker
If you could tell what thread to find at kp telling how to use the volt meter, I would be endebted.
Old Dec 11, 2005 | 11:16 PM
  #222
SFLG35's Avatar
SFLG35
To test the crank angle sensor set your digital multimeter to the AC setting. Put the black lead to ground and the red lead to the desired wire. With the car idleing you should measure a small voltage (say 1vac or so). As you slowly raise the RPM (in neutral) the voltage should rise with the RPMs. If the voltage does not rise with the rise in RPM then you have the wrong wire.
Old Dec 12, 2005 | 10:27 AM
  #223
SFLG35's Avatar
SFLG35
4. Mr pharmD - Dan - White - PAID - shipped
13. Philthy - Phil - Blue - PAID - shipped
17. Demonteverde - Ian - Blue - FL - PAID - shipped
KPTechnologies Window Up
3. Whoojong - Whoojong - TX - PAID - shipped
12. 0TRACK5 - carter - CA - PAID - shipped
13. 0TRACK5 - carter - CA - PAID - shipped
17. mborel7052 - Marc - CA - PAID - shipped
KPTechnologies Auto Door Locking
5. Shooter - Roger - PAID - shipped
KPTechnologies Sunroof Controller*
3. 0TRACK5 - carter - ?? - PAID - shipped
6. mborel7052 - Marc - PAID - shipped
7. Demonteverde - Ian - FL - PAID - shipped
9. BocaCoupe - Rob - FL- PAID - shipped
people who have not received their modules or have not contacted me. please let me know when you receive them
thanks
Old Dec 12, 2005 | 01:24 PM
  #224
klg35's Avatar
klg35
thanks for reply, if anything, it is different........hope to find out which wire so i can install this weekend.......if you 04 6mts sedan have it done, chime in please....
Old Dec 18, 2005 | 04:20 PM
  #225
nsanbyker's Avatar
nsanbyker
I'm building up the ambition to attempt this mod again. I have a good power source and have correctly spliced into the vdc switch. I am looking for a signal wire. For owner's of 2003.5 coupes with 6 speeds, what color wire did you use from the ecu harness. I have tried all of the brown wires and found one that had the correct idle voltage, but the voltage did not increase with the rev's. I am probably the only person who can take a simple 2 hour job and turn it into a 12 hour nightmare. Thank you in advance for any help.
