MREV2 + Motordyne 5/16"! What a combo!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Aug 14, 2007 | 01:16 PM
Ramon's Avatar
Ramon
I had the MREV2 + 5/16" Iso Thermal plenum spacer installed yesterday. WOW!!!!!! What a difference! The gains are very noticeable and the car pulls much harder after 3500RPM. I would highly recommend you do this MOD if you have a Rev up engine!! Believe me… YOU WILL NOT REGRET!!!!!!!!!!!!!!!!!!!!!!!!!
PS: I took my car to Performance Factory and they guys over there seemed pretty knowledgeable. They told me that I’m losing HP and torque because of my CAI. They said that our engines work better with the stock intake. He advised me to put my stock intake back and get a K&N drop-in filter. Would you guys agree with that? Please, give me your thoughts. Thank you!
Old Aug 14, 2007 | 01:34 PM
_jb's Avatar
_jb
+1 Listen to the PF guys...
I see that you have an '06 Coupe. The '06 Coupe is reported to have the best of all the Coupe air boxes. It has a better air inlet than other years. If you don't think this is true, put your old air box up for sale and see how quickly it sells.
Put your stock air box back in and get a Z-Tube and K&N filter and you 'll be good to go.
Old Aug 14, 2007 | 01:38 PM
Hi-Tech_G's Avatar
Hi-Tech_G
From: Pothole central and still ridin slammed...Beantown
I have the Z-tube with the K&N drop in filter and boy what a difference it makes. You even get the cool intake breathing sound.
Old Aug 14, 2007 | 01:39 PM
Ramon's Avatar
Ramon
Do I really need to get a Z-tube or should I just get the K&N filter? Is the Z-tube much better than my stock tube?
Old Aug 14, 2007 | 01:40 PM
Hi-Tech_G's Avatar
Hi-Tech_G
The Z-tube is better. Our stock intake tube seems to restrict the air but the Z-tube lets it flow a lot more freely. I noticed a big difference after installing my Z-tube and an even bigger one once I changed the filter.
Old Aug 14, 2007 | 01:43 PM
Ramon's Avatar
Ramon
Thank you!
Old Aug 14, 2007 | 01:50 PM
w33ps's Avatar
w33ps
Yeah the stock tube has this ridiculous resonator that goes down into the engine bay (you'll see what I mean when you take it out) which just swirls your air around instead of feeding it to the engine! The purpose is to make the engine quieter, something we want no part of!
Old Aug 14, 2007 | 03:31 PM
r10apple's Avatar
r10apple
I had the Motordyne guy look at my dyno after my install (and I have the AEM). Jeremy also tried to tune my car with the UTEC, and my a/f ratio is one of the more bizarre scenarios he has seen. My car does all kinds of crazy things and is unbearably hard to tune as is. The Motordyne guys says that the longer tube CAI creates some sort of problem when combined with hte spacer that actually causes one to lose the power.
I have simply been too lazy to get in my attic to find my stock airbox and get the Z-tube and filter...
Old Aug 15, 2007 | 06:53 AM
Hydrazine's Avatar
Hydrazine
Journeyman
I've tested several of the long tube CAI's on the dyno and they lose power every time.
And its not just with a spacer. They lose about 3+HP no matter what you hook them up to.
Old Aug 15, 2007 | 07:28 PM
Jamaica2G's Avatar
Jamaica2G
Florida G35 Club, General Member
The question I have is... have you guys tested the stillen intake? It's the same length as factory air box but it uses a cone filter.
Overall area through which air can be inhaled and angulation can cause differences. Any definitive testing complete?
Adrian
Old Aug 17, 2007 | 01:35 AM
Hydrazine's Avatar
Hydrazine
Journeyman
The short tube intakes like the Stillen and Pop Charger make about 2-3 HP.
But be sure to use the supplied heat shield. Its very important to not let your engine breath in hot air from the engine compartment.
hot air decrease power fast. 10-15 HP easily.
Old Aug 17, 2007 | 01:45 AM
battlebuddyP's Avatar
battlebuddyP
So let me make sure i get this correct the stillen and/or jwt will be better to use than wat i was going to buy aem?
Old Aug 17, 2007 | 01:48 AM
Cost a G's Avatar
Cost a G
^^yup I had an aem and it was only good for the sound.
Old Aug 17, 2007 | 01:51 AM
Hydrazine's Avatar
Hydrazine
Journeyman
Yes unfortunatly. The long tube intakes only make sound. That's about it.
Old Aug 18, 2007 | 12:05 AM
battlebuddyP
wow well that saves me a little bit of cash but, the jwt and stillen still make the growl noise right...? and it was gonna look good under the hood but thats not worth it. Ok another question because u guys are on the intake section. the rev up how do you know if ur engine is the rev up im not sure? and i was going to go with the kinetix rather than the spacer because its said to add a pony or 2 wat do you think...?
