FS: Sony 57" WideScreen Projection TV
Old May 6, 2007 | 03:16 PM
PimpinPearl's Avatar
PimpinPearl
Charter Member Florida G35 Club
SOLD SOLD SOLD
Hey there everyone. I am moving and this won't fit in my new place. Up for grabs is this great TV. I will allow those of you that I know or are familiar with to view in person due to safety reasons, otherwise I can't. Thanks and please email or pm me. $1200 obo
Here is the listing on craigslist:
Here is a great Sony 57" Wide Screen Projection TV with HDTV. I am includding the remote. Original Instruction manual. Remaining extended warranty through BestBuy. It expires 08/15/2007. There is a tiny scratch/imperfection on the bottom of the unit (shown in the picture) which you have to be up close to catch. I will take all the pictures you would like and I assure you this works, has no dead pixels, and has never been repaired. Unfortunately I will not allow people to come and see in person due to my working all the time and safety. Any other needs of verification, just ask. Thanks for looking. Oh, and I will accept paypal or cashier's check only.
Here is a description:
"Sony kp57ws510 57 Inch Widescreen HD Monitor with DVI Input"
Hi-Definition reaches new heights with the 16:9 Hi-Scan 1080i™ Display featured in Sony’s KP-57WS510 57" 16:9 Hi-Scan® Projection Television. See the difference Sony features make as you witness precise focus and sharpness as a result of our HD Microfocus™ CRT and Lens. In addition, Digital Reality Creation™ Circuitry produces amazing picture resolution for your viewing pleasure. Adjust size and placement of side-by-side P&P with MID™ X Circuitry to watch two programs at once. More features include Manual and Flash Focus® Convergence for precise and accurate adjustment, DVI-HDTV Input which secures access to High Definition content, and TruSurround® SRS® Audio (20W x 2) for explosive sound. Watch the excitement unfold in vivid detail with the KP-57WS510.
Hi-Scan 1080i™ Display --- Sony''s Hi-Scan1080i™ TV''s accept the full 1080 interlaced scanning lines (1080i) or 720 progressive scan (720p) from an external HDTV receiver or a compatible high definition digital satellite receiver. It also accepts 480 progressive (480p) scanning lines from compatible DVD video sources.
HD MicroFocus™ CRT''s --- By using an impregnated cathode and a denser phosphor layer, this CRT produces a 30% tighter beam spot compared to previous models.
Digital Reality Creation™ (DRC™) Multifunction Circuitry --- This Sony proprietary technology displays four times the the picture resolution compared to conventional models for great picture quality.
CineMotion™Reverse 3-2 Pulldown Technology --- is a fixed algorithm irrespective of source which preserves the integrity of movie film frames to create the best possible image
DVI-HDTV Interface (Digital Visual Interface) --- has been added for the latest generation in high definition television connectivity. A single wire delivers a full digital uncompressed HD signal that can be received from any DVI set top box.
Multi Image Driver (MID™ X) Circuitry --- With Sony''s Twin View™ 2 Tuner Picture and Picture you can watch 2 full motion pictures side by side. Together, Twin View, and Sony''s proprietary Multi Image Driver X Circuitry allows you to view analog along side of HDTV at the same time on the same screen. Also, with MID™ X both picture images are improved to 480 progressive image quality.
Flash Focus® Auto and Manual Convergence
3 D Digital Comb Filter
HD Detailer™ Wideband Video Amplifier
kp57ws510 Features
HDTV: HDTV Ready with Optional HD Receiver
HDTV Display Capability: 480p, 1080i, 720p
Projection Type: CRT Rear Projector
Screen Size: 57 Inch
Wide Screen (16x9) Format.
General Features
Aspect Ratio: 16:9
Closed Caption.
MID™-X.
MTS Stereo with SAP.
SRS TRU Surround.
White Balance: Automatic
3:2 Pulldown: CineMotion™ Reverse 3-2 Pulldown
Audio Output (in Watts): 40 Watts
Comb Filter: 3D Digital
Convergence: Flash focus, Manual
CRT's: HD Microfocus CRT
DRC™.
Energy Star Compliant.
Sleep Timer.
Steady Sound.
V Chip Parental Control.
Wide Band Video Amplifier: HD Detailer™
Inputs / Outputs
Composite Video: Front Input (1) , Rear Input (3)
DVI-HDTV: Rear Input (1)
RF: Rear Input (2)
Analog Audio: Rear Input (1)
Component Video: Rear Input (2)
S-Video: Rear Input (2) , Front Input (1)
kp57ws510 Supplied Accessories
Instruction Manual
Remote Control RM-Y909
AA Battery (2)
kp57ws510 Specifications
Video Features
Auto Channel Program
Caption Vision (CC)
Channel Fix
Channel Label
Channel Skip/Add
Clock/Timer Two Event
Energy Star® Compliant
Favorite Channel With Preview
Picture Freeze
Picture Jump
On Screen Display (English/Spanish/French)
Program Palette™ Presets (Vivid/Movie/Standard/Sports)
Scrolling Channel Index™ System
Sleep Function
Speed Surf™ Channel Selection
Video Label
Wide Mode (Normal/Full/Zoom/Wide Zoom)
XDS (Extended Data Service)
Manual/Auto (Flash Focus™) Convergence
Auto Pedestal Clamp
Auto White Balance
Dynamic Focus™ Circuitry
Dynamic Picture™ Processor Circuitry
Auto 16:9 Enhanced Mode
ID1 Detection (Auto)
Trinitone® Color Temperature
Audio Features
Auto SAP
MTS Stereo
Steady Sound® Auto Volume Control With BBE® Audio Effect
Auto Mute (Tuner)
Audio Output (Variable/Fixed)
Viewing bright, stationary images such as TV logos, and or continued usage of the 16:9 aspect ratio setting (normal Wide Mode) can result in permanent damage in the picture tubes used to display images in your projection TV
Weight: Approx.195 lbs.. (88.6 kg)
Dimensions: approx. 52 1/4 x 54 1/4 x 27 1/4 (1326 x 1377 x 690mm)
Inputs And Outputs
Component Video (Y/PB/Pr) Input: 2
Rear Composite Input: 1 Front/3 Rear
DVI-HDTV Interface: 1 Rear
S Video Input: 1 Front/2 Rear
RF Input: 2 Rear
Audio Out: 1 Rear
Power Requirements --- AC 120V 60Hz
Power Consumption --- In Operation: 260W In Standby: <1W
Attached Thumbnails FS: Sony 57&quot; WideScreen Projection TV-1-021.jpg   FS: Sony 57&quot; WideScreen Projection TV-1-022.jpg   FS: Sony 57&quot; WideScreen Projection TV-1-023.jpg   FS: Sony 57&quot; WideScreen Projection TV-1-025.jpg
Old May 6, 2007 | 10:29 PM
pullover20's Avatar
pullover20
FGC general member
thats a badass tV if only i had $1200
and space in my room
Old May 6, 2007 | 10:32 PM
PimpinPearl
you could have gotten 20" wheels and have $1000 left for the TV...lol
Old May 7, 2007 | 09:45 PM
PimpinPearl
bump
Old May 10, 2007 | 06:27 PM
w33ps's Avatar
w33ps
and to think i spent this much on my car when i could have gotten this sweet *** tv for when GT-HD comes out...
Old May 26, 2007 | 12:36 PM
PimpinPearl
bump..........
Old Jun 2, 2007 | 08:45 AM
PimpinPearl
SOLD TO Demonteverde! Thanks Ian!
alxmlr789
Dec 1, 2015 03:55 AM
djdiskino
Sep 29, 2015 07:18 PM
SheLLz
Sep 24, 2015 08:02 PM
Gio37
Sep 6, 2015 02:36 PM
