NISMO R Tuned Break Pads
Old Jan 31, 2007 | 03:09 PM
WILD121's Avatar
WILD121
Florida G35 Club, General Member
Can anyone tell me why they say I cant use these pads on the stock rotors. I need new break pads and want to get away from the stock OEMs. Will these cause my rotors to warp or groove dont undersand why it would fit the OEM brake setup but they say not to use them with the stock rotors.
http://www.intensepower.com/nir35wbrbrpa.html
http://www.intensepower.com/nirrebrpa35g.html
Old Jan 31, 2007 | 03:21 PM
Gilley's Avatar
Gilley
First, it's "brake."
those are competition style pads and they do not fit 2005 + models.
Get some Axxis Deluxe (I have them on the sedan) or the Axxis Metal Matrix. I got them from http://www.importrp.com/pbr.html.
Old Jan 31, 2007 | 03:50 PM
WILD121's Avatar
WILD121
lol didnt even notice
I do that all the time.
Crap
Old Jan 31, 2007 | 04:03 PM
WILD121's Avatar
WILD121
yeah i dont know what im going to get just yet but it has to be soon. I might need rotors to so i might be looking at getting cross drilled rotors but I havent seen any i like.
Old Jan 31, 2007 | 04:07 PM
INTENSEPOWER's Avatar
INTENSEPOWER
Hello,
First off these pads will work on 03-06 G35 without Brembo's. The part that says *Does not fit 05+ G* is a typing error (Which will be fixed right away).
The Part that says "not recommended for use with factory rotors" is, because it's a harder compound and will wear the factory rotors faster. It can be used with factory rotors if you wanted to use them. Thanks!!
-Mike
Old Jan 31, 2007 | 04:12 PM
Jeff92se's Avatar
Jeff92se
They also look to be a dual duty track/street pad. Meaning they will perform well at higher temps but at the expense of cold braking abilities. Not sure if this is the type of pad you want for your street car. Unless you track sometimes and are careful about the 1st few times you hit the brake pedal
Old Jan 31, 2007 | 04:22 PM
INTENSEPOWER
Hello,
He's got it ^ ! It looks like your in Orlando, so it stays pretty warm there. You would have to sacrifice a little bit of drive ability for the performance side of it.
-Mike
Old Jan 31, 2007 | 04:27 PM
WILD121's Avatar
WILD121
Yeah im still doing research on what pads i want and what rotors i want. It is a street car and i def. dont want to loose breaking capabilities. off to go Read. Thanks for the info.
Old Jan 31, 2007 | 04:54 PM
INTENSEPOWER
Hello,
If your looking to upgrade your brakes, but don't want to do a big brake kit... I would look into Racing Brake Rotors, and a good set of Hawk Pads! I carry both brands!
-Mike
Old Jan 31, 2007 | 05:03 PM
r10apple's Avatar
r10apple
Not to hijack the thread, but does anyone have an opinion as to whether this:
http://www.intensepower.com/grgrfrbug35c.html
the Greddy/Gracer front bumper has any fitament issues on our cars? Prep/paint time? This is a poly product, right???
Old Jan 31, 2007 | 05:07 PM
mdemonte's Avatar
mdemonte
Hawk Pads with out Brembo
Front
HPS Part: HB268F.665
Ceramic Part: HB268Z.665
HP PLUS Part: HB268N.665
Rear
HPS Part: HB370F.559
Ceramic Part: HB370Z.559
HP PLUS Part: HB370N.559
Lots of nice Rotors out there but that depends how much u willing to spend.
Old Jan 31, 2007 | 05:24 PM
WILD121's Avatar
WILD121
Its not Poly, The fitment should be pretty good. PM Chucky
Old Jan 31, 2007 | 05:27 PM
WILD121's Avatar
WILD121
Front
Rear
i thought nobody liked hawk. I could be wrong. Damn I need to do some serious reading.
Old Jan 31, 2007 | 06:07 PM
Gilley's Avatar
Gilley
Originally Posted by INTENSEPOWER
Hello,
-Mike
But the rotors are different sizes for 03-04 (11.65-inch x 0.94-inch) and 05-07 (12.6-inch x 1.1-inch). The calipers are correspondingly different too. Are the pads the same?
Old Jan 31, 2007 | 06:58 PM
WILD121's Avatar
WILD121
Just looked at the RB Rotors they look like quality rotors, a lot like the Rotora ones. Now i have decide on pads.
