Stereo installs in Miami area?
Old Sep 11, 2006 | 11:04 AM
MIAG35's Avatar
MIAG35
Originally Posted by RedG
Hold on let me get this str8 you want to add a factory NAV to your car that doesn't have it, and then mod it to watch DVDs?
yep, why is that crazy?? Im a rook!
Old Sep 11, 2006 | 11:05 AM
RedG's Avatar
RedG
Originally Posted by escobar929
yeah think your talking bout the 4080 box, it a great box.
then get a 10w6 or something similar. if you're only gonna go w/ one speaker make sure its powerful enough
IMO if its a lease it would be easier to swap out the HU, that way the OEM HU stays untouched, then when its time to give the car back you can swap out everything yourself
++1
Old Sep 11, 2006 | 11:09 AM
RedG's Avatar
RedG
No im not saying it can't be done, but I think it will involve more than just adding the NAV unit. I was just trying to think on the best route to go. I would just switch the HU with a pioneer NAV for the double din or even better the alpine w200.
Old Sep 11, 2006 | 11:11 AM
MIAG35's Avatar
MIAG35
dumb question, but what does double din mean?
Old Sep 11, 2006 | 11:12 AM
escobar929's Avatar
escobar929
FGC South Florida BOD
Originally Posted by MIAG35
good point. How hard would it be for the AC panel to be re-soldered?
for the dual climate control?
it brought them everything, from dash kit, ac controller, sub, amp, box, HU, PAC unit.
all i got from them was the amp kit and the wiring. it came out to a lil over $300 for everything to be installed
Old Sep 11, 2006 | 11:13 AM
escobar929's Avatar
escobar929
that it takes two slots
not crazy but a lot of work, when it could be a lot easier to swap out the HU
Old Sep 11, 2006 | 11:15 AM
Gilley's Avatar
Gilley
Florida G35 Club, General Member
From what I understand, you can't add a factory nav to a car that didn't come with it because of differences in the wiring harnesses. I also think it would likely cost as much, if not more, to install the factory nav in you non-nav car (if you could do it) than to install an aftermarket head unit with nav.
Old Sep 11, 2006 | 11:19 AM
RedG's Avatar
RedG
You definately need a bit a soldering skill to do the dual ac. You have to unsolder the button from your existing AC controller and resolder it onto the new one.
Old Sep 11, 2006 | 11:22 AM
escobar929's Avatar
escobar929
yeah it def does, it left mine out cause i hardly ever use it.
Old Sep 11, 2006 | 11:25 AM
MIAG35's Avatar
MIAG35
ok let me get this straight. Double din is when there are two slots and the HU would flip out of one of the slots? Or do you mean that it would be like an in-dash set-up? Thanks for taking the time to answer my questions fellas.
Old Sep 11, 2006 | 11:29 AM
RedG's Avatar
RedG
Double din:
http://www.crutchfield.com/S-4JKvQK7...0&i=500IVAW200
Single din:
http://www.crutchfield.com/S-4JKvQK7...earch=dehp80mp
Old Sep 11, 2006 | 11:31 AM
escobar929's Avatar
escobar929
sure bro np,
it would def be a in dash set up. if it was a single din, then it would be a flip out w/ an empty slot under, where most people put a lil open storage area.
here's a pic of mine if it helps
Old Sep 11, 2006 | 11:51 AM
_jb's Avatar
_jb
The old time standard radio size was governed by international standards. I forget exactly what DIN stands for, but in stereo head units it is the size of a standard, old-fashioned radio. They set a standard so all radios would fit all cars.
Most new cars avoid this and use OEM specific radio sizes... probably so everyone won't dump the OEM stereo and put in good stuff.
When stereo systems with video standards became popular, the standards committees made a new standard that was two single-DIN units stacked on top of each other. From then on the original DIN size was sometimes called single-DIN and the new, taller video size was called double-DIN.
Old Sep 11, 2006 | 11:56 AM
  #29
MIAG35's Avatar
MIAG35
sure bro np,
nice! how is that kenwood?
Old Sep 11, 2006 | 11:57 AM
  #30
MIAG35's Avatar
MIAG35
that makes sense, thanks. Why dont I see many single din set-ups? I kinda like the flip out.
