Vendor MOTUL Engine Clean Additive
Old Apr 15, 2011 | 01:18 AM
  #31
JEBperformance's Avatar
JEBperformance
best performance fluid
Old Apr 19, 2011 | 08:39 PM
  #32
JEBperformance
MOTUL Engine Clean Additive, Now available from JEB Performance.
The MOTUL Engine Clean is additive where you add to old engine oil prior to changing to new oil. Run idle for 20-25 minutes. And will clean all the deposits, and sludge. While oil is drained to be replaced by new ones.
Motul engine clean will not only clean piston bay, but also other small breather points inside your engine.
A normal oilchange when drained will leave deposits. Later to contaminate new oil.
Now when all the impurities are drained with old oil. To run your oil fresh, new, and for longer life. Reduce oil and gas consumption.
I know this for a fact. My customer's STI consumes about a quart of oil each and every month. Common problem with Subaru Turbo Engines. Flushing old oil with MOTUL Engine Clean, reduced oil consumption by more than half. Oil consumption as we may already know, increases with longer use of your vehicle. Older they get more oil and gas consumption. Is result of your engine accumulate more and more deposits.
Cleaning your oil, or flushing all deposits maintain performance. Equalizes all cylinders to fire with higher and equal compression. Prevents wear and tear on engine parts.
MOTUL Engine Clean is a care system for your Engine. Which is as easy or easier than your OIL CHANGE. Motul recommends Engine Clean on each and every oil change. However every other oil change is good enough.
<embed id="VideoPlayback" src="http://video.google.com/googleplayer.swf?docid=613819500230207789&hl=en&fs =true" style="width: 400px; height: 326px;" allowfullscreen="true" allowscriptaccess="always" type="application/x-shockwave-flash">
ORDER NOW MSRP $21
Single Oil Change
Case of 12 + FREE GROUND SHIPPING
Old Apr 28, 2011 | 08:57 PM
  #33
JEBperformance
Best wash for your engine internals
Old May 3, 2011 | 01:42 PM
  #34
JEBperformance
Bump Bump Bump
Old May 6, 2011 | 01:24 PM
  #35
JEBperformance
All of us @ JEB wishes you a wonderful Weekend.
Old May 12, 2011 | 11:11 PM
  #36
JEBperformance
Thursday Night BUMP
Old May 19, 2011 | 06:58 PM
  #37
JEBperformance
ORDER NOW MSRP $21
Single Oil Change
Old May 25, 2011 | 02:05 PM
  #38
JEBperformance
Longer life for your catalytic converters with MOTUL Engine Clean.
Old Jun 3, 2011 | 05:32 PM
  #39
JEBperformance
Call us toll free @ 866-445-0935 to place your order over the phone with greater discount. International customer please call us @ 213-985-3446.
Old Jun 14, 2011 | 07:30 PM
  #40
SlateBlue G's Avatar
SlateBlue G
would this help pinging i am getting under slight load?
Old Jun 15, 2011 | 01:05 PM
  #41
JEBperformance
You could give it a shot.
Old Jul 26, 2011 | 06:46 PM
  #42
JEBperformance
make sure to clean insides of your engine, at least every 3 oil change
Old Jul 27, 2011 | 05:24 PM
  #43
JEBperformance
Only MOTUL Engine clean guarantee 99.9% of sludge removal. I don't trust any other brand.
Old Jul 28, 2011 | 07:10 PM
  #44
JEBperformance
PM sent thank you
Old Jul 29, 2011 | 06:55 PM
  #45
JEBperformance
MOTUL Weekend Special, PM us between Mid Night July 30, 2011 and July 31, 2011. We will get back to you with special promotion price. Thank you for the opportunity.
