Engine, Intake and Exhaust Subforum dedicated to breather or engine mods (intakes, exhaust, pulleys, N/A mods etc.)
Motordyne shockwave exhaust install and tune
Old May 31, 2021 | 04:07 PM
JakeC's Avatar
JakeC
Hello,
I settled on getting the Motordyne Shockwave exhaust. Now I'm looking to find a shop to install and tune my 2010 G37x coupe. Any recommendations on tuner shops in New Jersey? Preferably near 07764 area code.
Thanks
Old Jun 29, 2021 | 05:04 PM
spoolin03's Avatar
spoolin03
Why do you need to tune it?
Old Jun 29, 2021 | 05:17 PM
JakeC's Avatar
JakeC
So I can get the most out of the mods and would like some sort of burble tune for the exhaust
Old Jun 29, 2021 | 05:19 PM
Birdie's Avatar
Birdie
Do you have test pipes?
Old Jun 29, 2021 | 05:21 PM
JakeC's Avatar
JakeC
no test pipes just getting the catback and I plan on getting long cold air intakes.
Old Jun 29, 2021 | 05:24 PM
Birdie's Avatar
Birdie
I doubt you will get the burble sound you are looking for with a tune. The stock cats will muffle the sound too much.
Old Jun 29, 2021 | 05:29 PM
JakeC's Avatar
JakeC
You may be right but it's worth a shot, since I want to tune for some performance anyways. I was originally planning on getting high flow cats but I was told they create a very raspy exhaust note.
Any suggestions on high flow cats that don't have too much rasp or drone? May do it down the line if I cant get the pops and burbles I'm looking for.
Old Jun 29, 2021 | 06:58 PM
There are high-flow cats with resonators. Fast Intentions sells a RHFC configuration. Pretty sure there's at least one or two other manufacturers who do the same.
But that's the ticket you want to open and deepen the exhaust up front... resonated high flow catalytic converters.
Or ditch the cats and OEM shorties entirely for a pair of long-tube headers.
ARK makes a set of high-flow cats with Helmholtz resonators. Matched up with your Shockwave cat-back, that would be all kind of fun. Although I'm remembering there might have been a clearance issue with your AWD Coupe. Anyway, go research that.
Old Jun 29, 2021 | 07:13 PM
JakeC's Avatar
JakeC
Thanks for the info! Will definitely look into that.
Will cats like that pass inspection? Or throw check engine light?
Old Jun 29, 2021 | 07:41 PM
Birdie's Avatar
Birdie
Not sure about the sniffer. But it should pass the visual. it probably will throw a cel but that is where your tune comes in to clear the light
Old Jun 29, 2021 | 07:53 PM
Depends what state you're in. Check your DMV's website, and call some local speed shops for advice.
As for the CEL, FI has this long O2 sensor bung which keeps it in range.
Old Jun 29, 2021 | 07:58 PM
JakeC's Avatar
JakeC
good to know thanks!
Old Jul 2, 2021 | 12:24 AM
AnotherVQ's Avatar
AnotherVQ
CWorksDesign sells test pipes with helmholtz
View this post on Instagram
Old Jul 2, 2021 | 06:41 AM
Didn't know about cworksdesign. "resonated *****", LOL.
Unfortunately for the OP, note the comment that says RWD only.
Old Jul 2, 2021 | 07:03 AM
AnotherVQ's Avatar
AnotherVQ
Oh yeah. Okay.
Cworks makes admin intakes and various steel reservoirs.
