370z Nismo Differential Swap
Old Jan 22, 2023 | 01:49 PM
Gavalo01's Avatar
Gavalo01
Hey guys, new to posting here but ive been lurking this forum for the past year or so. I've got a 2012 G37 Auto Sedan
I've been reading a lot about final drives and differentials and im looking at swapping a 2015/2016 370z Nismo AT differential.
From what ive scoured on the web, the 2015 and 2016 models have auto transmissions with a VLSD as well as the 3.69 ratios. Perfect swap for a mild boost from the 3.3 open diff, right?
Now since both transmissions are automatic, this should be a plug and play right? is there anything i should look out for that i may have missed?
-Gael
Old Jan 23, 2023 | 11:11 AM
RobC7's Avatar
RobC7
2015+ AT have 3.69 and MT have 3.9xx gears.
It should be a plug and play and it would be a good time to fix your differential bushing if you haven't done so yet. Regarding boost and a shorter gear, you need to keep in mind if you make too much power a 3.3 diff (w/LSD) may actually help you put the power down better.
Old Jan 23, 2023 | 09:13 PM
Gavalo01's Avatar
Gavalo01
​​​Okay sweet that's what i thought! I'll be getting some Z1 bushings and the z1 diff cover + fluids, already have a diff brace installed.
Fortunately im not really looking to make big power, i just want to take my G on a track as well as some very windy roads around my area. Although if anything changes i think my 8.5 rear tireswill be my biggest limiting factor when it comes to putting power down
RogerSmith
MODDING 411
May 28, 2016 05:04 PM
37hevn
May 20, 2012 08:07 PM
Blackjack
Picture Share G Coupe
24
Apr 22, 2009 10:28 PM
