Help Transmission similarities
Old Mar 24, 2021 | 12:36 AM
GinfinitiSpot's Avatar
GinfinitiSpot
Hello. I'm new here. Question for all present. Is the automatic transmission in the infiniti G25 the same as the infiniti G37?? Also, how do I convert awd into rear wheel drive ?? Both cars are 2011. Thanks for your prompt response.
Old Nov 3, 2022 | 09:53 AM
HubCityAk's Avatar
HubCityAk
bump..any word on this? Wondering if its just the bell housing can be swapped? Or the whole transmission
Old Mar 25, 2025 | 09:05 AM
naterem1988's Avatar
naterem1988
anyone ever figure this out? can a g25 teans fit if bellhpusing is swapped?
Old Mar 27, 2025 | 12:29 PM
socketz67's Avatar
socketz67
Community Builder
Maybe start with the problem you are trying to solve? You have a G25 and the transmission has failed (as determined by a qualified mechanic)? You need to replace it and all you can find are 7ATs that came out of G37s since there were so few G25s sold? I have been around these cars for years and this is the first time I've seen the questions asked, so I'm not sure if any of us have first hand knowledge.
I believe there is a fuse you can pull to disable the front diff on an AWD, although I'm not sure why one would want to pay more for an AWD then disable the feature. To each his own I guess.
Seems that many others have done the same, take a look: https://www.myg37.com/forums/d-i-y-i...wd-switch.html
sportsdude512
Nov 10, 2010 05:54 PM
davepj32274
Sep 23, 2010 06:32 AM
GT-R
The M - Spot
Nov 30, 2009 02:05 AM
