Help Rear Axle 2013 G37X coupe
Old Mar 14, 2021 | 12:24 AM
MyGisMyChild's Avatar
MyGisMyChild
Went to replace my wheel bearings today and all went well with the installation but now I have a CV axle clicking noise. The teeth on the axle look to be pretty worn down compared to the sharp teeth in the new bearing, so there is a little bit of play/wiggle room which is what I think is causing the noise. I'm assuming the last bearing was partially seized to the axle from a little bit of rust build up which is why I didn't hear the noise before. So I now need to get new rear axles too but can't figure out which ones will fit my car. I have a 2013 G37X coupe, so will any coupe axle fit or do I need to find a specific one since its the AWD model? I'm finding a lot for the sedan AWD but can't seem to find any specifically stating coupe AWD. Any help would be greatly appreciated!
Old Mar 15, 2021 | 04:18 AM
Said Amir's Avatar
Said Amir
Yes any coupe axle will fit, just make sure it is for a coupe and not a sedan.
Old Mar 17, 2021 | 05:19 PM
MyGisMyChild
Thank you for the info my dude!! You were indeed right. Since i have the AWD coupe I would need to get ones specifically for the AWD coupe for the front axles, but as far as the rear axles its the same as a RWD coupe. Thats how it was with the bearings as well, so I was assuming it was the same but just needed a second opinion before pulling the trigger.
ChinkyChoy
41
Jul 8, 2023 11:13 AM
OldG2NewG
60
Jun 11, 2020 11:43 AM
Hooni2e
Nov 15, 2017 02:26 PM
tscani
Jul 28, 2016 10:51 AM
Gthangftw
Apr 5, 2016 09:27 PM
