Any tips on putting transmission back into engine?
Old Mar 2, 2021 | 06:31 PM
GodlikeRage's Avatar
GodlikeRage
Hello
doing a clutch job myself but ffs I cannot get the transmission back mated to the engine. I pre checked the new clutch disc and pilot bearing and yes they both fit onto the transmission input shaft/splines. I’m pretty sure it’s aligned because the clutch alignment tool fits inside. I’m on the ground doing this and literally it’s taking me the longest amount of time. On the home stretch here, just the easy parts left like the driveshaft/exhaust/bleed/shifter but holy shift I’m on the verge to give up with this **** not lining up and tow it to the dealer lol.
Old Mar 2, 2021 | 09:56 PM
stealthee's Avatar
stealthee
Sometimes you have to clock the trans a little. I remember one time I was trying to fight a transmission back in and tried for over an hour. I finally took a quick break, walked back out and it slid right on. Also might need to put the trans into neutral.
Old Mar 2, 2021 | 11:30 PM
Birdie's Avatar
Birdie
As Stealthee mentioned it may need to be clocked.
I was wasn't able to get mine in until I started to rotate it back and forth.It wouldn't slide but I was able to walk it in a little more than have way. Had to finish mating it with the transmission bolts.
Old Mar 3, 2021 | 08:58 PM
TheDigitz's Avatar
TheDigitz
Curious how this is progressing OP? I see this repair in my future.
Also - what do you guys mean when you say "clock" the transmission during installation? Curious.
Old Mar 3, 2021 | 09:36 PM
ILM-NC G37S's Avatar
ILM-NC G37S
Definitely try clocking the gearbox. It is just a matter of getting the input shaft splines lined up with the clutch disc. Going to have to do this soon on my old beater pickup.
Originally Posted by TheDigitz
...what do you guys mean when you say "clock" the transmission during installation? Curious.
Rotating the gearbox back and forth along its "centerline" until the input shaft splines line up with the clutch disc splines. Once everything lines up it should slide right on.
Old Mar 4, 2021 | 09:52 PM
TheDigitz's Avatar
TheDigitz
Thank You. Appreciate the information.
OP - still curious how this is coming along.
LAMOKI FLARE
Aug 5, 2019 07:46 PM
Nehro
Sep 22, 2017 12:39 PM
Andrew Leal
Apr 4, 2017 01:46 PM
Phimphasone
Apr 12, 2013 12:22 AM
cyberjock4hire
Nov 8, 2007 08:26 PM
