Help CEL flashed and now car has a constant sputter
Old Aug 1, 2020 | 09:57 PM
Kameronismyname's Avatar
Kameronismyname
I was driving home quiet spirited then the CEL light flashed and I immediately noticed something was wrong. I limp it home and now noticed the car has a sputter while idling . Any idea what the issue is ? The car did have an issue with the factory catalytic converter. I'm crying on the inside I hope I did not just mess up my only car .
Old Aug 1, 2020 | 10:38 PM
stealthee's Avatar
stealthee
Flashing CEL usually indicates a misfire.
Old Aug 2, 2020 | 01:54 PM
Kameronismyname
so the constant sputter at idle is a misfire ? I dont know if it the spark plug or coils . Or even if the catalytic converter is clogged
Old Aug 2, 2020 | 03:07 PM
juster's Avatar
juster
What does the code say?
Old Aug 2, 2020 | 04:47 PM
stealthee's Avatar
stealthee
It could be any of those. You need to do a proper diagnosis and process of elimination.
Old Aug 2, 2020 | 08:44 PM
Kameronismyname
there is no code. After it flashed it went away. I'm guessing it spark plug or coil packs. My dad gf volvo had the same sputtering problem until we changed the coils and spark plugs
Old Aug 2, 2020 | 08:45 PM
Kameronismyname
thanks hopefully new oem spark plugs and coils will fix the rough idle the car has 150k miles so I'm guessing they were never changed smh
Old Aug 3, 2020 | 04:56 PM
Conboss's Avatar
Conboss
Even if the CEL went away the the code should still be there saved in memory until cleared or the ecu is reset. I would scan it just in case to see if it can be narrowed down to a specific cylinder.
Old Aug 3, 2020 | 07:37 PM
stealthee's Avatar
stealthee
Not when it flashes. A flashing CEL doesn't necessarily save anything. It is just a warning for multiple misfire.
Cortelle
Jun 24, 2020 08:27 AM
Mr.Jones
Intake and Exhaust
12
Nov 9, 2018 04:16 PM
Neddy_G37
Oct 5, 2018 05:27 PM
Razorr
Oct 8, 2014 11:33 AM
