HELP! Rough engine performance - stock
Old Jul 11, 2020 | 02:58 PM
eymen B's Avatar
eymen B
Hello all,
The scenario is:
when the car is cold, the engine has a rough performance when accelerating.
Its a little bit of vibration, loud engine noise and roughness.
However after sometime of running (10mins+) it becomes the symptoms go away.
Im running on 182k KMS and this has been going on for about 25 to 30k KMS.
i change the engine oil with fully synthetic oil on time along with the filter.
Ive changed the engine bushings thinking they may have been worn out but the problems persist.
Has anyone had the same issue and got it fixed? Or have any idea what the problem may be?
Old Jul 11, 2020 | 05:01 PM
ILM-NC G37S's Avatar
ILM-NC G37S
When was the last time the throttle body's and MAF sensors were cleaned/have they ever been cleaned?
Old Jul 11, 2020 | 06:32 PM
Conboss's Avatar
Conboss
Which engine mounts did you use? Poly or solid are always rougher, if they’re stock then that’s not the issue
Old Jul 11, 2020 | 11:03 PM
eymen B's Avatar
eymen B
Im not sure if the showroom service center ever cleaned them but i can say they have not been cleaned in the last 100k kms cause since i stopped servicing the car there.
I was reading up on the net and some sites said to get the fuel injectors cleaned and replace the engine temperature sensor?
Old Jul 11, 2020 | 11:04 PM
eymen B's Avatar
eymen B
I used the OEM mounts which is why i figured they were not the issue.
jimt29
Jun 6, 2020 03:44 PM
solarg37
12
Apr 21, 2013 11:49 PM
RX Law
Motorsports / Track
26
Jan 7, 2012 05:25 PM
r6rider211
Car Care & Detailing
Sep 22, 2011 10:40 AM
