Help Cruise Control not working after hard brake
Old Jun 19, 2020 | 11:45 PM
hiddensalami's Avatar
hiddensalami
Any help on this would appreciated. I was doing some spirited driving on some backroads and a deer jumped in front of me and I had to brake, HARD. Luckily I stopped and nothing happened. A few days ago, I tried to use my cruise control (I have the tech package with the ICC) and it didn’t work. Started to do a little research and I believe the brake pedal switch may be the problem. Today I was trying some stuff out and if I held the brake pedal up (opposite from the normal usage direction) and tried to use CC and it worked? I have to keep the brake pedal up to use CC, but as soon as I move my foot away from the brake pedal, CC stops working. Seems like something needs adjusting or replacing. Anyone know what to do? Thanks!
Old Jun 20, 2020 | 11:20 PM
hiddensalami
No one? I was looking under the pedals again today and saw that the brake pedal wasn’t making enough contact with a little switch it looks like. The pedal stopper is still there so that isn’t a problem.
Old Jun 21, 2020 | 10:22 AM
ILM-NC G37S's Avatar
ILM-NC G37S
When you slammed "HARD" on the brake pedal, more than likely the ASCD (cruise control) switch was knocked out of whack. According to the FSM, there should be less than 1mm between the rubber pad and the threaded portion of the switch body (C1 distance/blue arrow):
It is just a matter of unlocking the switch, adjust the position according to spec, and lock it back down. Just make sure you do not "over adjust" the switch to where it is pressing the brake pedal down.
Old Jun 22, 2020 | 12:37 AM
hiddensalami
Awesome! I put a little double sided tape in between the sensor and pedal stopper and it works! Thanks for you help man
Noddy11
Nov 17, 2025 02:40 PM
LeonJames
Oct 4, 2023 03:19 PM
JEBperformance
Nov 17, 2011 01:33 PM
chasemyaccord
Mar 10, 2008 12:01 PM
