Help Differential
Old Apr 30, 2020 | 05:55 PM
D5074r's Avatar
D5074r
Differential
Can you fit a 2010 Convertable g37 Diff on a 2008 g37 if they are both AT and Rwd?
im tryin to explore my Diff Options doesnt matter if its the same gear ratio or not
Old May 7, 2020 | 07:51 AM
projectpanda13's Avatar
projectpanda13
The vert diff will work on your 08. 370z AT will also work.
G35/350z in the same transmission configuration is interchangeable too, after you swap the stub axles (its because of the sensor)
GTM
13
Nov 9, 2016 05:00 AM
Hydrazine
Exterior FS
Mar 10, 2009 03:34 PM
GregUMR
19
Jan 22, 2008 01:58 PM
