P0021 p0524 p0300 after changing galley gasket
Old Jan 14, 2020 | 06:55 PM
710merlin's Avatar
710merlin
Hello ladies and gents
as the title says I replaced the galley gaskets over the weekend. However when I left today I had a very rough idle and after about 10-20 miles CEL popped and was thrown into limp mode. (Can’t rev above 2.5k rpm) replaces oil when servicing the galley gaskets.
here is the question I pose though around the timing valve solenoid I noticed some oil residue stained all over the front of the timing cover plate were the solenoid is. So if there is a leak coming from the o-ring on the solenoid and the solenoid is bad could that there by drop the oil pressure and cause the p0300 and rough idle ?
also! 2011 infinity g37x 140k
all stock
Old Aug 23, 2023 | 10:01 PM
Nandosan's Avatar
Nandosan
Damn nobody replied lol but bro did you ever figured it out? I’m having that issue rn
Old Aug 24, 2023 | 09:36 AM
KennethPetty's Avatar
KennethPetty
Possible bad solenoid caused oil leak, low pressure, rough idle, and error codes. Investigate and replace if needed.
dagdiy
59
Nov 22, 2023 06:46 PM
ABg
21
Oct 10, 2022 11:25 AM
TheDevilsG
43
Mar 19, 2021 01:30 PM
Raffi D
Jan 12, 2020 09:54 PM
leo.u
16
Oct 23, 2017 09:35 AM
