Help 1 quart low after 2100 miles
Old Oct 17, 2019 | 08:43 AM
Lance Mac's Avatar
Lance Mac
Hello, I have a 2013 G37X, automatic with 36,000 miles on it. I don't put a lot of miles on my vehicle and thought I would check the oil yesterday and it was down a quart, been about 4 months since the last oil change. I don't see any oil on the ground so not sure what's going on, any ideas? Thanks.
Old Oct 17, 2019 | 09:38 AM
Eugenius's Avatar
Eugenius
If you dont see oil anywhere outside of engine, means it was burned inside of the engine.
Means potential problems with pistons, cylinders, piston rings.
Piston rings can be coked because of sludge, cylinders walls cab be damaged by dust or metals, pistons can be damaged, etc etc
How often do you change oil and what type of oil do you use?
Old Oct 17, 2019 | 09:44 AM
Lance Mac's Avatar
Lance Mac
Thanks for the info......wow....well that sucks....I been using the same Firestone by me for years, every 5,000 miles it what they tell me with the type of oil used but I have always gone in at 3,000 miles instead. I don't know the brand off hand but it's synthetic 5W-30.
Old Oct 17, 2019 | 11:06 AM
PNW_IPL's Avatar
PNW_IPL
Did you check it cold overnight? Sometimes can be tricky getting an accurate reading. If I part on slightest incline it shows qt low.
Old Oct 17, 2019 | 11:09 AM
Eugenius's Avatar
Eugenius
Potentially they did not do oil change for you, or used very low quality oil. I always stay away from quick lube change station like Firestone and Jiffy
Here
You can go to another reputable place or even dealership and do the oil change and ask them to drain some of the oil into an empty, clean container (like empty 1 quart oil bottle) and sent to a lab for oil analysis.
You also can bring your own oil for the change, I would say oil with high detergent agents, run for 3k and repeat
Old Oct 17, 2019 | 11:13 AM
Lance Mac's Avatar
Lance Mac
Thanks for the reply, I checked it at work before I left for lunch, was a level parking spot so should of been okay.
Lance Mac's Avatar
Lance Mac
Thanks for the information, yeah didn't think about that at all...hmmmmm sucks you can't trust a lot of places....I will check into this, thank you.
Old Oct 17, 2019 | 11:16 AM
PNW_IPL's Avatar
PNW_IPL
Another thing oil change shops do oil change warm so perhaps they got an incorrect reading while filling. I seriously doubt your car burned that much. The vq37 is solid and not widely known for oil consumption issues.
Old Oct 17, 2019 | 11:19 AM
Atowsley's Avatar
Atowsley
Just an FYI, I have the same year/model and I'm not experiencing that kind of oil consumption. I don't notice much of a drop in oil level and I change mine out at 5,000 miles.
Old Oct 17, 2019 | 11:23 AM
Lance Mac's Avatar
Lance Mac
Thanks....I will try a different shop all together, possibly the dealer on this next one and go from there.
Old Oct 17, 2019 | 11:46 AM
Eugenius's Avatar
Eugenius
It is possibility, but still shop's mistake. They buy oil in barrels and use smaller measurement containers to fill up engine with new oil.
But it is not warm oil. They might did not put correct amount of new oil.
Did the topic starter check the level after the oil service?
Old Oct 17, 2019 | 11:49 AM
Lance Mac's Avatar
Lance Mac
No I didn't check it after
Old Oct 17, 2019 | 01:02 PM
Eugenius's Avatar
Eugenius
It's not good to drive any car with low oil level which is below 'L' line.
Just buy 1 quart of good full synthetic oil, like Mobil 1, Pennzoil, Valvoline 5w30 and add it, but don't overfill. The measure stick should show oil line between L and H.
Monitor for another 1k miles, see if your oil actually gets burned.
Old Oct 17, 2019 | 01:11 PM
antirice's Avatar
antirice
I always wonder does "L to H" on the dipstick equals to 1 quart of oil? My car has always consumed oil on a consistent basis, but it's always within the "OK" range in the chart below.
Old Oct 17, 2019 | 02:58 PM
It was pretty common for the VQ35DE to burn a half-quart of oil between oil changes. At least, common online. I can't imagine the general public carrying an extra quart of oil around in the trunk just because they owned a 6-cyl Nissan.
The VQ37HR in my G has never burned oil, insofar as I know.
mastapro
General Tech Questions
18
Feb 29, 2016 03:35 PM
Koval88
14
Jan 16, 2016 09:48 AM
ChrisBLKG
Dec 20, 2010 04:19 PM
Infiniti7
Mar 11, 2010 01:09 AM
willio10244
14
Aug 6, 2009 09:28 AM
