Car temperature stays at H
Old Sep 15, 2019 | 11:26 PM
TesaG37x's Avatar
TesaG37x
Hi everyone! I have a G37x...today while I was driving the car started to jerk. The temperature gauge stays at H even after the car has been off for 5 plus
hours. Can someone give me any idea on what this could be? TIA.
Tesa
Old Sep 16, 2019 | 05:26 AM
Surfnazi's Avatar
Surfnazi
Check cooling fans, look for coolant leaks
Old Sep 16, 2019 | 10:03 AM
TesaG37x's Avatar
TesaG37x
I’ve checked all of those
Old Sep 16, 2019 | 12:46 PM
Conboss's Avatar
Conboss
When you say temp gauge at H, you mean at H when car is off (Key off) as well? The gauges go to their "home" position on shutdown.
Old Sep 16, 2019 | 06:51 PM
TesaG37x's Avatar
TesaG37x
The temperature gauge stays at H within 10 mins of me starting my car. After being off over night, it went back down to C which is normal. It seems that the heat isn’t escaping the hood.
Old Sep 16, 2019 | 08:24 PM
crookncastle's Avatar
crookncastle
when you say 10 minutes of starting car, did you mean 10 minutes of driving or 10 minutes of idling in park? what do you mean by the heat isn't escaping the hood? if you have no leaks and the cooling fans are working i would check to see if your thermostat might be stuck. feel the top and bottom radiator hoses, they should feel like the same temperature while running your car and the fans start to come on when the engine temp rises.
Old Sep 16, 2019 | 09:07 PM
TesaG37x's Avatar
TesaG37x
10 minutes idling in park. I presses the gas a few times
too, to see if the car was going to jerk like yesterday but that didn’t happen. My next guess was to check the thermostat and I ordered one and will start that process tmrw. How hard is it to change? When I felt the hose earlier the temperature weren’t the same so it clue me that it might be the thermostat. By chance do you have a picture of the hose? Just Incase I need to order a new one, I want to make sure I order the right one and all this will solve the problem.
Thank you.
Old Sep 17, 2019 | 12:50 AM
slartibartfast's Avatar
slartibartfast
You can look up part numbers on www.discountinfinitiparts.com
Old Sep 17, 2019 | 02:11 AM
TesaG37x's Avatar
TesaG37x
Thank you! I will check the site out.
jaylin001
Apr 21, 2019 12:31 PM
Elohel
Apr 8, 2014 10:41 PM
GeezerB
Nov 15, 2013 07:22 PM
xx44
Sep 23, 2010 11:13 AM
