Tune up gone Wrong
Old Aug 25, 2019 | 06:13 PM
Sharp2415's Avatar
Sharp2415
Tune up gone Wrong
Looking for help, I just changed the spark plugs on my car (went with some NGK’s instead of denso) I have after market I takes (Stiller Gen 3) removed them to get to the plugs. Thought everything went smooth but now my car won’t start. I read not to unclip a switch on the throttle body (which I did) is that it? Or could have I blown a fuse some where? Any ideas will help
thanks!
Old Aug 25, 2019 | 08:01 PM
PNW_IPL's Avatar
PNW_IPL
Check the battery. Did you disconnect it?
Old Aug 25, 2019 | 09:54 PM
juan goose's Avatar
juan goose
Undoing the connector to the throttle body would not cause this unless you didn't connect it back. Would check over all the connectors to the plugs.
Old Aug 25, 2019 | 10:32 PM
crookncastle's Avatar
crookncastle
do you mean engine won't crank or cranks but won't run? why would you suspect a blown fuse unless you know you arced something?
Old Aug 26, 2019 | 03:48 AM
jpowersjr2's Avatar
jpowersjr2
Denso all the way.
msmching
Jan 11, 2013 07:05 PM
