Help P0011 & p0524
Old Jul 7, 2019 | 12:41 PM
Jrubio98's Avatar
Jrubio98
P0011 & p0524
Hi, I recently opened up my whole timing cover and replaced the gallery gaskets because I had gotten the code p0011. After I replaced the gallery gasket and put everything back. I still got the code and I am still on limp mode. And I also got a P0524 code which indicates low oil pressure. I am wondering if any of you guys have any ideas as to why I am still getting these codes and still in limp mode when I had already took apart everything and replaced the gallery gaskets. I also have to clear the codes on my car with a scanner to go out of limp mode. Wondering if any of you guys can help I would appreciate it a lot!
Old Jul 8, 2019 | 12:50 AM
slartibartfast's Avatar
slartibartfast
There are a couple of threads that detail the gallery gasket replacement and I think there's a video in the DIY forum. Review those to make sure you performed all the proper steps. If you did it right, try unplugging the battery for awhile. Sometimes the ECU is a bit slow in clearing faults that have been fixed.
Old Sep 2, 2020 | 06:03 PM
Jimmy Early's Avatar
Jimmy Early
I have the same codes and I’ve replaced both VVT Solenoids, changed the oil and initially, it drove beautiful for about a week then the code came back. It kills me because if I clear the code the car drives fine. It just keeps going into limp mode after a little while. Any one have anything in this?
Old Sep 15, 2020 | 09:29 AM
TOnG's Avatar
TOnG
Might want to try replacing the oil pressure switch
Glenn2008
Oct 10, 2023 01:49 PM
ABg
21
Oct 10, 2022 11:25 AM
Rose
Jul 7, 2020 03:09 PM
Edwin Verdugo
Nov 29, 2019 10:56 AM
ill12will8
Oct 26, 2015 10:09 PM
