Help Sea Foam Spray in G37 - What's the Best Method?
I've been having some rough idling on warm start ups (occasionally stalls) so to try and narrow down the issue, I'm going to begin by using some Sea Foam spray. Where our G's have two throttle bodies, what would be the best way to go about doing this?
Sea Foam Suggest:
- Getting car up to operating temp and spraying the full can into the throttle body before the butterfly valve. Then turning the car off for 15 mins then a spirited drive for 5+ miles.
For our cars, which of the following two options would be better:
1. Applying half the can to one side, shutting the car off then driving for 5+ miles. Then repeat for the other side.
2. Applying half the can to one side, then apply the other half to the other side while the car is still running, shutting off, then driving 5+ miles.
I'm probably over thinking this, but I just wanted to make sure I wasn't doing anything that could potentially harm the engine.
Thanks in advance!
Sea Foam Suggest:
Thanks in advance!
Gotcha - will probably do that then. I haven't cleaned throttle bodies before; I presume all lines should be left connected to it when its unscrewed and cleaned? Also, i'm guessing the butterfly valve shouldn't be moved due to potentially causing issues with the electric motors - would I be right in saying that?
How many miles does your car have ? If I was stalling I would probably also consider doing the spark plugs if they haven’t been changed. Very easy to do if you’re cleaning the TB
I run it through the gas tank and have done it through the brake booster hose as well. Best to change spark plugs after if you do it that way. You can also use it in your oil but then again after that you'll need to do an oil change after a couple hundred miles.
