Shifting problems
Old Feb 24, 2019 | 07:48 PM
Jo3nahxS's Avatar
Jo3nahxS
Shifting problems
hey what’s going on team G37 so I’ve notice todaymy 2011g37xS won’t let me shift while on DS mode it’s shifts on its own or in Low rpm any ideas
Old Feb 24, 2019 | 11:16 PM
slartibartfast's Avatar
slartibartfast
My first suggestion is to not use a phone when posting. Your post is pretty much unintelligable.
Old Feb 24, 2019 | 11:20 PM
Jo3nahxS's Avatar
Jo3nahxS
[QUOTE=slartibartfast;4233055]
My first suggestion is to not use a phone when posting. Your post is pretty much unintellig. My apology I should of double check I edit the text
Old Feb 25, 2019 | 09:35 AM
Bostonreefer's Avatar
Bostonreefer
What do you mean it wont let you switch gears? Could you elaborate? The system is designed to auto shift if its putting the motor in a situation where it could either kill it self or, stall...... Is this what you mean?
Like if you go to upshift to soon it will not let you, and also give you audio feedback.
I Assume if you do not shift in time before red line it will automatically shift for you as well though I have never experienced this.....
What does your display in gauge cluster show DS? or 1?
Old Feb 25, 2019 | 12:01 PM
Jo3nahxS's Avatar
Jo3nahxS
It won’t even pass 3kRpm it will shift on low rpm so is not like is getting abuse
Old Feb 25, 2019 | 12:30 PM
ILM-NC G37S's Avatar
ILM-NC G37S
Sounds like limp mode- if the engine wont rev past 3k RPM's...
Any CEL's?
Old Feb 25, 2019 | 12:33 PM
Jo3nahxS's Avatar
Jo3nahxS
Any CEL's?
no CEL as of yet
Old Feb 25, 2019 | 01:10 PM
ILM-NC G37S
If the engine wont go over 3k RPM's in any drive mode than there is something going on- not necessarily with the transmission.
If you have a decent code reader it wouldn't hurt to check and see if there are any pending codes.
Old Feb 25, 2019 | 01:25 PM
Jo3nahxS's Avatar
Jo3nahxS
mis shifting smooth just won’t let me like set on it like usually
Old Feb 25, 2019 | 04:54 PM
slartibartfast
Since you cannot adequately describe to us the symptoms, you should go straight to Nissan or Infiniti dealer and have them check for codes. If you're in North America, any autoparts store can read codes, and usually do it for free.
Old Feb 26, 2019 | 02:10 PM
Jo3nahxS's Avatar
Jo3nahxS
So the only code I’m getting is P0197 Engine Oil Tenoerature Sensor circuit low input
Old Feb 26, 2019 | 02:19 PM
slartibartfast
Google is your friend.
https://www.obd-codes.com/p0197
One of several sites that explain OBDC codes.
Snypos
Oct 25, 2014 02:09 PM
Dasilvy28
Aug 23, 2012 10:35 AM
bloodhound
Picture Share G Coupe
Aug 13, 2007 05:42 PM
