Pinging/spark knock?
Old Nov 24, 2018 | 12:52 AM
Gus_Mahn's Avatar
Gus_Mahn
Is my 50,000 mile '11 G37X sedan pinging near the shifts? I only run premium (10% ethanol). It only happens at WOT and near redline. Next fill up I'm going to try 3-4 gallons of 99 octane no lead to see if it goes away. I've searched, and haven't seen much on the subject.
Old Nov 24, 2018 | 02:43 PM
slartibartfast's Avatar
slartibartfast
It's not detonation, it's from exhaust heat shields. Every x owner and their brother report detonation only to discover it's the heat shields.
Besides, detonation doesn't occur at red line, it occurs at low rpm. Unless you're boosting...
Old Nov 24, 2018 | 10:17 PM
Gus_Mahn's Avatar
Gus_Mahn
Thank you for the reply. I did spend plenty of time searching with no results. After searching exhaust rattle there were lots of results. It's pretty loud in the cab when it happens. There's even a TSB on converter shields rattling. Exhaust rattles seem very common on Nissan's. Though this rattle is very different than what i usually hear, I'm pretty sure you are correct at this point. For sure detonation does happen at WOT. It's just more audible at lower engine RPM's. I would think that the OE's use pretty conservative WOT timing along with detonation sensors to limit warranty claims.
Old Nov 25, 2018 | 08:55 PM
slartibartfast
Cylinder conditions are not conducive to detonation at redline. See The Internal Combustion Engine in Theory and Practice, Volume 2 by Charles Fayette Taylor.
GTI631
Jan 27, 2011 01:10 AM
HKSG37s
May 21, 2010 03:05 PM
C@ciQ
Intake and Exhaust
30
May 23, 2009 07:14 PM
Blackjack
Picture Share G Coupe
69
Jan 12, 2009 07:42 PM
