Intermittent loss of power, clears immediately after restart
Old Apr 21, 2025 | 03:17 PM
Marcel4t's Avatar
Marcel4t
Originally Posted by beefychicken
The thread that never ends..... i know its old, but i feel compelled to provide an update on how I fixed this MAF gremlin.
The limp mode continued to happen and happened again, again, again and the fix was always the same. Clean the MAF, swap the MAF, rinse – repeat. So since I did begin to notice it was always the same side -Bank 1 (passenger) - I bought jumper cables that let me connect the right wiring to the left MAF and the opposite is true.
Drove, limp mode showed up, codes said Bank 1 (pax side). Note that this is now years later ater having grown accustomed to limp mode (muscle memory?).
Regardless, I had an epiphany! so I chopped one of the jumper harnesses in half and then chopped off a section of the Bank 1 MAF connector wiring (cut back several inches into the car harness) and spliced in the newly created pigtail.
This new connector and section of wiring fixed the issue and it continues to stay fixed over the past several years and several 10’s of thousands of miles.
Not to be happy with having it fixed, I decided to re-fix it. So I ordered two pigtails from a reputable eBay huckster and then replaced both sides using proper heat shrink splices, staggered, wrapped etc. Looks and works good! I claim victory!
Hey, just came here because I'm having the same problem. Just wanted to ask, I'm basically gathering that you replaced your pigtails for both your MAFs? You think the connectors themselves were messed up?
Old Apr 21, 2025 | 09:00 PM
beefychicken's Avatar
beefychicken
My guess was either a bad crimp on one of the connector pins or one of the pins was damaged and not making contact.
still have had no problems till this day.
Matthew Diehm
Jan 15, 2019 08:21 AM
Neddy_G37
Oct 5, 2018 05:27 PM
Joshua Pilgrim
Mar 28, 2018 05:22 PM
EnerG
12
Nov 7, 2015 05:30 AM
SkyMG37x
Feb 25, 2010 09:15 AM
