2009 g37 sedán limp mode!!??
Old Jun 17, 2018 | 04:52 PM
Albertos64's Avatar
Albertos64
Hey I’m new to this forum but anyways, I have a 2009 g37 stock with 81,000 but does have muffler delete. It currently has the vdc off and slip light on (does need a break change which I’m going to due tomorrow because the pads are low) . So yesterday I was driving for about an hour and out of nowhere I lost power and my car wouldn’t accelerate. Can this be because of my brakes ? And it went into safe mode/limp mode ? My brakes are bad which I thought it was because of that ? Any ideas ?
Old Jun 17, 2018 | 11:24 PM
qmantran's Avatar
qmantran
has absolutely nothing to do with your brakes.
do you have a service engine soon light on? Get the codes read.
Hopefully you don't have a damaged oil gallery gasket. The repair is easily over $2,500+
Old Jun 18, 2018 | 05:29 PM
Albertos64's Avatar
Albertos64
No it doesn’t have any codes or light on but when I restarted my car it ran fine again. Car runs fine but I changed the air filters and cleaned the maf sensors hopefully it works. If not then I’m going to clean both throttle bodies and see if that does anything. Because I read on here that people said they had to replace the throttle bodies or it can be that oil gasket which is an expensive job😒 but hope it’s not something big
Old Jun 19, 2018 | 06:39 PM
Surfnazi's Avatar
Surfnazi
Check battery first along with your maf sensors. Make sure you got them seated in right direction, screwed down, and plugged in
Dembflyr
Jan 1, 2026 11:20 PM
Diode Dynamics
Lighting/Cleaning Products
40
Nov 30, 2021 02:30 PM
Diode Dynamics
127
Nov 30, 2021 02:20 PM
Diode Dynamics
258
Mar 19, 2021 04:14 PM
b2autodesigns
Brakes/Suspension
467
Jun 8, 2018 04:53 PM
