Bad idle???
Old May 27, 2018 | 02:06 AM
Zori_V36's Avatar
Zori_V36
Bad idle???
So I recently bought a new Stillen grounding kit for my sedan and changed the alternator. When the car is on park itll do a little baby misfire for about 4 seconds and idle normal. Then after a few monents later the car idles perfectly at 750rpm and then it drops to 500rpm and the motor shakes a little then go it goes back to 750rpm and it does that constantly. Any Ideas?
Old May 27, 2018 | 10:05 PM
Surfnazi's Avatar
Surfnazi
Did you check battery water level
Old May 28, 2018 | 01:21 AM
saywat?'s Avatar
saywat?
U should be idling at 650 not 750
Old May 28, 2018 | 01:23 AM
Zori_V36's Avatar
Zori_V36
I have an Optima Yellow Top, its gel and either way that shouldnt be the problem it’s something else but moving the grounding kit to different ground points didnt help and my i tested the alternator and its perfect. But idk what the problem is
Old May 28, 2018 | 10:34 AM
Surfnazi's Avatar
Surfnazi
Make sure grounding bolts are set and dbl check alternator why a yellow and not red do you have stereo eq
Old May 28, 2018 | 12:27 PM
Zori_V36's Avatar
Zori_V36
can you explain that again i dont quite understand. Thank in advance!!!
Old May 28, 2018 | 01:25 PM
slartibartfast's Avatar
slartibartfast
He means, why do you have a yellow-top instead of a re-top? Do you have a stereo equilizer (or amp)?
Old May 28, 2018 | 02:57 PM
Zori_V36's Avatar
Zori_V36
Oh yeah. I have bags, amp, subs, basically alot of electronics in the car thats why i went with the yellow top
Old May 28, 2018 | 04:28 PM
Surfnazi's Avatar
Surfnazi
Hmm wonder if stock alternator can support all that with 1 battery
Old May 29, 2018 | 02:15 AM
Zori_V36's Avatar
Zori_V36
the optima battery is known to handle way more that
Old May 29, 2018 | 08:48 AM
Surfnazi's Avatar
Surfnazi
Not with that much running I would at least run 2 batteries or capacitors you're putting alot od strain on a stock system. If you have capacitors I'd check those to see if they are the issue
Old May 29, 2018 | 02:42 PM
G37OB's Avatar
G37OB
Have your tried performing idle relearn?
Old May 29, 2018 | 06:33 PM
Zori_V36's Avatar
Zori_V36
how would you do that?
Broseph
Nov 30, 2020 01:49 PM
