Help!
Old May 6, 2018 | 01:30 AM
Meez403's Avatar
Meez403
Exclamation Help!
Hey Team!
What's this part called?
Was cleaning my throttle bodies everything went fine with the passenger side. I discovered that the last owner of the car who did the CAI Install broke the hose for this part and it's literally hanging on its life.
Thanks In advance!
Old May 6, 2018 | 07:59 AM
Entcee's Avatar
Entcee
You can safely remove it and just use a straight hose. The consensus is that it's a resonance chamber that cuts down intake noise.
Old May 6, 2018 | 09:02 AM
Meez403's Avatar
Meez403
Thanks for the reply! So I don't necessary need that rectangle thing? I can just bypass and use a hose to connect to the valve covers? would it mess with the ECU removing that rectangle thing and just using a straight hose?
Old May 6, 2018 | 09:14 AM
Entcee's Avatar
Entcee
Correct you don't need it, and your car (ECU) won't even know it's gone.
Old May 6, 2018 | 05:12 PM
Surfnazi's Avatar
Surfnazi
You can just cap it with a plastic lid and electrical tape or epoxy
Old May 6, 2018 | 06:35 PM
Meez403's Avatar
Meez403
Thanks for all the replies folks! I was also looking into the part mentioned above. Seems like I can't locate the part..
I've been using this site https://parts.endrasinfiniti.ca/, can anyone point me to the right direction? on where I can find this certain part?
Uho001
Dec 18, 2009 08:49 PM
jnguyen
Oct 20, 2008 11:26 PM
