Help with HP
Old Feb 28, 2018 | 11:56 AM
CalG37's Avatar
CalG37
Help with HP
I recently purchased the Motordyne shockwave E370G for my 2008 coupe purchased Motordyne ART pipes , Crank Pulley, and already have K&N cold air intake installed what else do i need for more Horsepower? once it’s all installed I’m going too get a ECU remap/Flash & Dyno
Old Feb 28, 2018 | 12:21 PM
RMB5190's Avatar
RMB5190
uh huh....Z1 headers, IM and the tune should top you out in the power department. Hope you upgraded sway bar, springs/coils, tires, rims along the way.
Old Feb 28, 2018 | 12:31 PM
CalG37's Avatar
CalG37
What are a good brand of headers and do you know the price range with those
i need too upgrade a few of those items you commented under I have got new wheels and rims Niche gunmetal gray
Old Feb 28, 2018 | 12:39 PM
mitheralice's Avatar
mitheralice
You can regain lost HP through the drivetrain by getting an upgraded flywheel and driveshaft.
An intake plenum spacer, bored throttle bodies, headers like RMB said, would all help you out on the dyno.
RMB is right though, make sure your car can handle the extra power with the right suspension set up.
Old Feb 28, 2018 | 01:24 PM
RMB5190's Avatar
RMB5190
No plenum for the VQ37VHR; not like the G35 had available. Throttle body port, Admin intakes, Z1 headers and ported upper intake manifold.
Z1 two piece rotors, wheels and driveshaft to shed weight.
Old Feb 28, 2018 | 02:36 PM
CalG37's Avatar
CalG37
Would getting a tune before adding the aftermarket parts into my car help my G handle it better
Old Feb 28, 2018 | 02:37 PM
CalG37's Avatar
CalG37
Do you guys know of any bucket seats worth getting ?
Old Feb 28, 2018 | 05:44 PM
IMfam0us's Avatar
IMfam0us
No, get all your parts on and then get a tune. Otherwise you are just wasting money, dont want them guessing at things before the parts are on the car.
Old Feb 28, 2018 | 09:47 PM
Calg37USMC's Avatar
Calg37USMC
Try using the search button lots of great info, not trying to be rude but you’ll find plenty of build threads and Dyno sheets available to you.
Uho001
Dec 18, 2009 08:49 PM
jnguyen
Oct 20, 2008 11:26 PM
