Could be the bearing?
Old Jul 4, 2017 | 06:05 PM
mdanish4's Avatar
mdanish4
I see whole wheel shakes with the clunk/knocking. Could be the bearing? Only happens when steering fully turned to right..
Old Jul 4, 2017 | 09:13 PM
mdanish4's Avatar
mdanish4
Could be this lower control arm outer ball joint? But man I don't see any play at all
Attached Thumbnails Could be the bearing?-img-20170704-wa0015.jpg   Could be the bearing?-img-20170704-wa0016.jpg   Could be the bearing?-img-20170704-wa0014.jpg
Old Jul 5, 2017 | 12:42 AM
JustROLLIN's Avatar
JustROLLIN
Its really hard to tell based on your clip... That said, I am would be willing to venture on the CV joint. Its along the range of noises and they are fairly cheap. But, I would bet someone not blowing up **** will chime in tomorrow and advise more accurately.
Old Jul 5, 2017 | 05:42 AM
mdanish4's Avatar
mdanish4
My car is a Rwd therefore it doesn't have CV joints/front axel..
Old Jul 5, 2017 | 01:04 PM
zer099's Avatar
zer099
Is it consistent with the spin of the tire? Meaning if you go slower is the noise happen slower? Being RWD and seeing as there are only a few things that would be spinning up there I would check your rotor (front and back), then make sure your tie rod isn't impacting a wheel weight as you are at full lock, and then look to the bearing.
Old Jul 5, 2017 | 01:19 PM
mdanish4's Avatar
mdanish4
I haven't tried turning on high speed but I would say it is consistent. I have recently upgraded to BBK kit and I don't recall this happening when I was on oem brakes (or I never turned like this so i could notice).. I didn't under about the tie rod part can you explain please?... Also, I checked bearing in it seems perfectly fine..
Old Jul 5, 2017 | 01:25 PM
zer099's Avatar
zer099
At full lock your tie rod is very close to the wheel, it is why it has that curve in it. If you changed up the set-up (bigger wheels, lowered, or the like) the tie rod location could change and might be making contact with your wheel. The wheel weights used to balance our tires are placed, typically, near the edge of the wheel, and they stick out some. It might be the wheel weight impacting the tie rod when at full lock because they are that close. Turn the wheel full lock and look to see how close the tie rod is to the inner edge of the wheel.
Old Jul 5, 2017 | 01:32 PM
mdanish4's Avatar
mdanish4
At full lock your tie rod is very close to the wheel, it is why it has that curve in it. If you changed up the set-up (bigger wheels, lowered, or the like) the tie.....
Ohh wow.. Did not even think about this. I will check and report.. I hope this is the culprit because I am going crazy since last month.
Old Jul 6, 2017 | 12:50 PM
AARONHL's Avatar
AARONHL
Are you lug nuts tight????
Old Jul 6, 2017 | 12:53 PM
mdanish4's Avatar
mdanish4
Dude.. You are a life saver.. Much thanks to you.. Apparently what happening was like you suggested one of the wheel weights were touching the sway bar.. Lol.. Never would have figured this out..
Attached Thumbnails Could be the bearing?-image-20170705_220347.jpg   Could be the bearing?-20170705_221409.jpg
Old Jul 6, 2017 | 12:56 PM
zer099's Avatar
zer099
Glad you got it worked out!
