A weird RPM drop, do you guys have it?
Old Jul 4, 2017 | 09:56 PM
Machelen's Avatar
Machelen
Originally Posted by Yellafella
I just watched the vid you linked. Maybe your car has trouble identifying what gear it should be in at that speed?
Initially I was thinking the same thing. But after the thread I just linked I m not so sure anymore cuz ecm reflash helped only couple weeks.
But it since it helped couple weeks, I do think it is something with ecm causing it.
However it is way out of warranty, an inspection cost 150 and may not detect anything.
Old Jul 4, 2017 | 09:57 PM
Yellafella's Avatar
Yellafella
Do you feel any mechanical action when the rpms bounce up and down? If not, it could be just a computer/ecu related problem.
Old Jul 4, 2017 | 09:59 PM
Machelen's Avatar
Machelen
No mechanical action, i do not feel jerk and surge, just plainly Engine speed goes down as i am shutting it off for a quick sec
Old Jul 4, 2017 | 10:31 PM
Yellafella's Avatar
Yellafella
And does this happen in manual mode too or just Drive?
Old Jul 4, 2017 | 11:28 PM
Machelen's Avatar
Machelen
it it is in both modes
Old Jul 4, 2017 | 11:51 PM
Epiphany's Avatar
Epiphany
My 2012 does this here and there, no consistency but it's generally around that speed and letting off the gas fully. Bogs down a bit until it coasts down a little slower or I give it a quick blip of the throttle then it settles in nicely. Confused transmissions. Maybe a Canadian thing?
Old Jul 5, 2017 | 12:01 AM
Yellafella's Avatar
Yellafella
Well, if you cleaned your maf and throttle bodies and it is still doing that, it could be a pvc/vacuum related problem. If those issues aren't it, there may be a problem with the torque converter. It's the torque converter's job to match the speed difference and keep the rpms constant. Since you said this happens with your foot off the gas there is no load going to the wheels so they're spinning freely when this problem occurs. That means your driveshaft is moving faster than your engine flywheel.
Old Jul 5, 2017 | 12:07 AM
Yellafella's Avatar
Yellafella
It could be fuel related, such as a pump or filter. Or something getting stuck. I would check fuel pressure just to make sure. Also get your tranny and fluid checked. I wouldnt worry about it too much unless it compromised drivability/safety. Just keep an eye out in case it gets worse.
Old Jul 5, 2017 | 12:51 AM
Machelen's Avatar
Machelen
maybe, it bugs me to see it doing and hear the exhaust sounding it is shutting fown
Old Jul 5, 2017 | 12:53 AM
Machelen's Avatar
Machelen
Yea Rs maybe I will just keep driving it until some problems come up. The only thing I can think of is the fuel damper as occasionally I do hear the noise caused by it described by other people.
Old Jul 5, 2017 | 07:56 AM
KAHBOOM's Avatar
KAHBOOM
Super Moderator of Pwnage
Might want to also check the 370 z forums. Same engine so someone there might have experienced and fixed he same thing.
Old Apr 9, 2021 | 12:41 PM
Calebdouthit's Avatar
Calebdouthit
did you ever figure out what this was? My car does the same exact thing.
Old Apr 9, 2021 | 10:41 PM
Tatus's Avatar
Tatus
It's a dirty MAF or throttle body...I'd clean the throttle body and just replace the MAF instead of screwing around with that
Old May 21, 2022 | 04:11 AM
  #29
JSohn's Avatar
JSohn
Mine always does the same at second gear..
Have you fixed the issue?
TB cleaned. MAF cleaned. Nothing shows on scanner.
Old Jun 4, 2022 | 09:11 PM
  #30
BennettDeering's Avatar
BennettDeering
Exclamation This issue needs to be revisited and solved, even still mid way through 2022.
I have the same exact problem in my VQ37 Q50 and I posted a thread on the Q50 forum about this that is nearly 55 replies long with almost 4 times more words, description and discussion than your thread here has. My video that I use to demonstrate what you and I are experiencing is also long, high definition, steadily filmed and accompanied by timestamp descriptions of the dips occurring in the footage.
I need you to reply to me and tell me if you ever sprung further investigation into this issue or ever found a solution besides the temporary yet unsuccessful ECU reflashing at the dealership. I have attempted every suggestion on this forum with the exception of one or two things; and ruled out even more suggestions that were made on my Q50 forum thread.
Please, I ask that you give my thread a read and get back to me with perhaps some useful information.
https://www.infinitiq50.org/threads/.../#post-1456586
ATHENSG37
Jun 12, 2021 12:23 PM
Mr.Mitchell
Jun 6, 2017 06:59 PM
MalbecG37S
Jan 25, 2015 09:35 PM
Nosnibor
Apr 7, 2014 04:43 PM
Duc3588
General Tech Questions
Jan 19, 2011 10:53 PM
