Automatic Transmission Problem?
Old Jun 15, 2017 | 02:39 PM
G37xS-Life's Avatar
G37xS-Life
Well got my G back. The dealership was not able to replicate the hard downshifting. However, they did download and install an updated software for the transmission and flushed the system with another 14 quarts of Matic S again.
Since picking up my G, I have driven it about 80 miles in various speeds and slow downs. No hard downshifts were observed. Even did the shifting manually in DS mode and so far every gear has shifted very smoothly. One thing I did notice was that my 3rd gear pulls a little bit harder than before and I am not sure how that happened though. It felt like a sudden burst of power came to life when the gear shifts to 3rd and at around 40 mph.
Will keep you guys updated and see how things go.
Old Jun 15, 2017 | 04:15 PM
Could be the updated software, glad the dealer is at least taking care of this for you.
Should also see a bit smoother downshifts.
Old Jun 15, 2017 | 08:12 PM
G37xS-Life's Avatar
G37xS-Life
Yes, I am glad the dealer is taking this issue seriously and acting very responsibly. I did bring a printout of my email showing that I specifically asked for a 3x drain and fill prior to bringing my G in for a transmission fluid change. I also mentioned that I verbally emphasized that 3x drain and fill was something I want to have done and not the power flush that was actually carried out.
In terms of smoother downshifts, I did not notice it while the G was in "D" mode. However, when I switched to "DS" mode, the automatic downshifting that occurs when speed decreases were noticeably smoother.
I am hoping the hard downshifts and the thump/clunk sound experienced from before is just a one-time thing. It was very startling and jarring when it happened last week.
Old Jun 16, 2017 | 05:33 PM
Surfnazi's Avatar
Surfnazi
Did you check your trans mounts
Old Jun 16, 2017 | 06:06 PM
G37xS-Life's Avatar
G37xS-Life
The dealer did and said there were no problems there.
Old Jul 26, 2017 | 06:34 PM
kroy's Avatar
kroy
So I have this problem too on my 7AT.
Got the update from dealer, which seemed to make the issue less frequent (it was already infrequent though).
Got my mechanic to do a transmission flush. Pretty sure they didn't use machine because I don't think the shop has machine.
I still notice the issue. Usually in 4th gear.
At this point, I'm thinking it's just the transmission getting old. Car has 80K miles. I bought it from Infiniti at 55 and can't be sure how it was taken care of before.
