2011 IPL Coupe feels slow
Old Apr 11, 2017 | 12:09 AM
All_the_Poniez's Avatar
All_the_Poniez
Last Saturday I pulled the trigger on a beautiful 2011 IPL 6mt Coupe with 52k miles, one owner and a good price. During the test drive I was impressed by the acceleration when over 3k rpms, but I was also coming from driving a new impala that had zero *****.
Now it's a week later, I know the car much better and I just feel like the throttle response is "Dumbed down". I've read a ton of info about guys losing power and having issues with the 7at shifting slow but this is different. It's not that it's lost power per se, but when I stomp on the gas it climbs rpms pretty slowly and doesn't have much "Oomph" until it's 3500-4000 rpm range.
No CEL, no weird operational problems. All stock. Does this sound normal? I've always had slow cars and a truck with a built 454 so I'm no expert.
Old Apr 11, 2017 | 12:30 AM
PNW_IPL's Avatar
PNW_IPL
Wow.
This is unreal.
Old Apr 11, 2017 | 12:41 AM
All_the_Poniez
Originally Posted by PNW_IPL
Wow.
This is unreal.
Care to elaborate? I'm no stranger to fast cars and motorsports, I'm just not feeling 348 horses
Old Apr 11, 2017 | 12:47 AM
the93owner's Avatar
the93owner
Well you wouldn't feel 348 horses under 3-4k RPM, as the power doesn't peak until after 7k.
Old Apr 11, 2017 | 01:28 AM
All_the_Poniez
I'm not giving a very good explanation, I'm more concerned about the throttle response than the power. Even when not in gear if I hit the gas it seems to climb rpms slowly and there's a slight delay from the time I press the pedal to the time it responds.
Old Apr 11, 2017 | 08:55 AM
Surfnazi's Avatar
Surfnazi
Trying fogging car with sea foam once or twice then put in new plugs. Also drain refill trans diff fluid
Old Apr 11, 2017 | 12:46 PM
Kris9884's Avatar
Kris9884
Maybe this is obvious but, you said you weren't in gear and it was happening too. Be sure your foot isn't on the brake at the same time, it'll keep you from revving up while the brake lights are on.
Old Apr 11, 2017 | 01:08 PM
PNW_IPL's Avatar
PNW_IPL
I say this because i experience it too
Old Apr 11, 2017 | 01:09 PM
PNW_IPL's Avatar
PNW_IPL
Sometimes my ipl feels snappy quick and ruthless. And on some days it feels like a brick. No idea why. No codes no nothing just feels like a brick trying to accelerate
Old Apr 11, 2017 | 01:10 PM
PNW_IPL's Avatar
PNW_IPL
Im almost positive its the trans. The trans has a mind of its own. Definitely next big mod is transgo.
Old Apr 11, 2017 | 01:33 PM
All_the_Poniez
I see you're from PNW; WA by any chance? I wanna meet up with another IPL owner and ride along to feel the difference
Old Apr 11, 2017 | 01:36 PM
PNW_IPL's Avatar
PNW_IPL
Yes. Im in Tacoma man. Pm me
Old Apr 11, 2017 | 01:56 PM
EnYcee-G's Avatar
EnYcee-G
I don't know if this matters Bc the car is a MT, but doesn't the factory install a 0-60 limiter which affects throttle response? Or is that just in the AT cars.
Bc I have a 2011 IPL 7AT and the minute I drove The car after removing the 0-60 speed limiter and changing the tire rating index using a hypertech programmer, it feels more alive. I also reset the ECU before using the hypertech.
Old Apr 11, 2017 | 01:57 PM
PNW_IPL's Avatar
PNW_IPL
I need this where do i get one?
Old Apr 11, 2017 | 02:03 PM
All_the_Poniez
Awesome, I'm up north but I am down that way pretty often. I'll hit you up later on
